Slider Window Seals
Discussion in 'The Garage' started by daleearnhardt01, Nov 11, 2003.
  1. daleearnhardt01
    daleearnhardt01 1/2 ton status
    Aug 29, 2002
    3,223
    Richmond, VA
    Hey yall the side windows are leaking when it rains heavily. When I go back to see where its comin in, it seems to be wet in that felt channel where the glass slides. Any ideas on how hard it is to replace that felt stuff and should I replace all the rubber/seals on the windows while Im in there?. Ive heard that the felt from LMC is bad so I guess Id have to get it from GM or a glass shop.
  2. dyeager535
    26,977
    My sliders (before I went with solid windows) had bad seals on them, but they didn't leak. IIRC, there are small drains in the channels, make sure they aren't plugged up.
  3. daleearnhardt01
    Aug 29, 2002
    3,223
    Richmond, VA
    What do I need to do to check that, remove any glass or is it in plain sight? /forums/images/graemlins/thumb.gif
  4. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    The drains should be in the lower channel piece in plain view, there is like 2 or 3 of them thru the whole length of the slider.
  5. daleearnhardt01
    Aug 29, 2002
    3,223
    Richmond, VA
    Cool I think thats the problem, theres lots of crap in the channel. Ill give it a looksee this wknd. /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
