sliders vs. front fender
Discussion in 'The Garage' started by sandawgk5, Aug 20, 2006.
  1. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    Does anyone have pictures of what they did with the lower portion of the front fender where the bolt is when they welded sliders inplace of the rockers? I am doing this in the near future and I am not sure of what to do with the front fender interface. Do you just say F it and weld the fender to the slider? Open to suggestions also.
    Ira
  2. Skigirl
    Skigirl 1/2 ton status
    Apr 2, 2001
    2,563
    Los Angeles, California
    I didn't want to weld mine in case the fender (wheel well) needed replacement. Right now it's just sitting there, but I'm going to drill a hole in the slider and bolt the well piece to it.
  3. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,992
    130
    I just left the fender floppin in the wind
  4. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    Tab sticking up off the top of the slider?
    A couple 5/16" bolt heads there won't look too bad, maybe some Stainless Button Heads?
  5. SCOOBYDANNN
    SCOOBYDANNN 1/2 ton status
    Sep 4, 2001
    2,129
    21
    El Paso, TEXAS
    i think that would look good.
    with that said---i welded mine:D
  6. sandawgk5
    Oct 28, 2003
    6,881
    That is what I was thinking I am not to concerned on looks as you can tell by the pics I have posted before:D . If I weld it and need to replace a fender I can always cut it and grind it down and weld the new one. If I have to replace fenders it will prolly be with tube only and not sheet metal anyways:D .
    Ira
  7. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    i let mine sit on top of it
    4x4 iron said not to as the weld will tear when the body flexes
  8. JIM88K5
    JIM88K5 1/2 ton status
    Apr 27, 2001
    1,384
    Vancouver, Wa
    Bingo.... Thats what I was thinking...
  9. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Welded to slider . If fender needs replacing , grind flat after cutting off .
  10. ntsqd
    Nov 28, 2002
    3,381
    So. CA
    Exactly why I suggested a tab with bolt(s).
