slight backfire throught tbi
Discussion in 'The Garage' started by chvymudin3388, Jan 8, 2007.
  1. chvymudin3388
    chvymudin3388 1/2 ton status
    Mar 3, 2005
    374
    orange grove ,tx
    im getting a slight pop pop pop when i start it up and barely even rev it juist bump it and it goes popopop what is it? why is it doing it this... it also does it when warm sometimes
  2. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    Could be a number of things. Bad plug wires/cap rotor. When was your last tune up?
    Are the wires on in the right fireing order? Have you checked your timing?
    Are you getting any trouble codes?
    Could also be a stuck or burned valve.
    Bad timing chain and gears. How many miles on the engine?
  3. chvymudin3388
    Mar 3, 2005
    374
    orange grove ,tx
    motor was recently rebuilt it has new sparkplugs new cap new rotor new pick up coil new coil new module new fuel pump the timing chain seemed to be in good shape though head job just done
  4. chevyguybc
    chevyguybc 1/2 ton status
    Nov 12, 2003
    524
    Vancouver Canada
    im having same problem with my s10 87 2.8 TBI
    it will run great, but then sometimes it will bog down and not rev up freely, and backfire through tbi unit
  5. Thunder
    Jul 20, 2000
    8,946
    Northeast Nevada
    If you recently had a head job. Check the valve adjustment. You may have a intake valve adjusted too tight.
  6. chvymudin3388
    Mar 3, 2005
    374
    orange grove ,tx
    it only randomly does it under accerleration very little normally when cold it will like go pop pop pop when you accelerate and stop like three times most of the time or when you put a small load on it when its cold
  7. chvymudin3388
    Mar 3, 2005
    374
    orange grove ,tx
    uhm i found out that my vacuum for my brakes to my intake is rather loose could this be causing my random popping?
  8. kwissman
    kwissman 1/2 ton status
    Jan 14, 2006
    118
    Austin, TX
    It could be a lean condition causing the backfire. Check your fuel pressure. The pump may be going out.
  9. Chaddy
    Chaddy 1/2 ton status GMOTM Winner
    May 23, 2005
    4,110
    Salt Lake City,Utah
    It sounds electrical. Even though you have new wires, 1 of them could be bad....I would spray the wires with a water/dishsoap solution and see...
