Slight hesitation right off the line
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by weisel, Apr 28, 2002.
  1. weisel
    weisel 1/2 ton status
    Feb 22, 2001
    491
    Laveen, AZ
    When I just barly touch the gas to go (like after a stop sign and not in a hurry), the engine hesitates. What could it be?
  2. tacoma972
    tacoma972 1/2 ton status
    Jan 6, 2002
    114
    West Point, Ga.
    check your vaccum. mine was doing the same thing and i found out the carb had a vaccum leak in it. also got a vaccum check valve and put it be tween the carb and the distrbuter. make sure the vaccum check valve is open towards the carb and not the distributor
  3. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    accelerator pump
    what carb?
  4. yunit
    yunit 1/2 ton status
    Feb 24, 2000
    3,068
    Oakland, NJ
    EFI or CARB??? If it is EFI...I just got over this problem, it was my EGR valve. The EGR was the original and was all cruded up so the valve was sticking open just a tad at idol and would fully open to early when I would give the truck a little gas; at about 1000-1300RPM and would make the truck run lean, I bought a new EGR and the truck purrs now.
  5. weisel
    Feb 22, 2001
    491
    Laveen, AZ
    It is a stock quadrajet. I don't know if I even have an egr valve. Really, a check valve in the vacume line to the distributor. I thought it was suppose to have vacume/not have vacume, depending on the engine load and speed. Really, a check valve? After school today, I'll check the accelorator pump, make sure it is pumping right when the gas is touched, and not delaying slightly.
  6. dyeager535
    26,979
    When my dist. was messed up (stuck advance weights) in neutral, if I floored it, and kept my foot in it, I could stall the truck. From a light, if I started rolling slowly, then floored it, it wouldn't bog. Any quick apply of the pedal from a stop would result in bog/stall/backfire.
    I'd check into timing. I've got my vac advance hooked to ported vac., with no check valve, and it runs fine. Guy just last week on the car list went from manifold vac to ported vac and solved his low end sluggishness.
