Slight Skip/Jump when turning right sharply.
Discussion in 'The Garage' started by JoeAngelicchio, Jul 22, 2006.
  1. JoeAngelicchio
    JoeAngelicchio 1/2 ton status
    Feb 18, 2000
    628
    South Central Ontario, Canada
    I just noticed it today in a shopping mall parking lot. I was turning right (probably all the way right) when I noticed the left end skip/jump very mildly through the turn. When I turned not as sharply, it wasn't there. I did the same turning left and it didn't do it, just right. I replaced the front axle u-joints 2 summers ago and it's not a daily driven truck so I didn't pack on the mileage. But all the ball joints are still the original ones (it's an 86 w/10bolt). I still have to make time to raise the front and check for anything loose but the quick visual doesn't show anything obvious. Busy working on my kids playset so I thought I'd get some ideas first before I start on the truck.
  2. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    Sounds like u-joints
  3. JoeAngelicchio
    Feb 18, 2000
    628
    I was afraid someone was going to bring those up!!!:eek1: But so soon!!! Do they just wear out quickly? They are half decent ones, but with the grease fitting(I'm pretty sure, have to check again), not the non-greasable ones. Just can't remember the brand, got them from NAPA. OK, I plow my driveway during the winter and that's 2 winters. I guess that can accelerate the wear somewhat. But so soon!!!!:mad:
  4. SkysTheLimit
    SkysTheLimit 1/2 ton status
    May 23, 2003
    530
    Tampa, FL
    It was a civic. Nothing wrong with your truck.
  5. gmcjimmy4x4
    gmcjimmy4x4 1/2 ton status
    May 6, 2005
    132
    Sacramento, CA
    my jimmy has always done the exact same thing. I used to worry about it, but it seems to be a normal ocurance according to everyone ive talked to.
  6. neverendingproject
    neverendingproject 1/2 ton status
    Jul 24, 2005
    1,637
    Tulsa, OK
    My 2wd does it. I think its the alignment
  7. diesel4me
    Jul 24, 2003
    17,577
    945
    Massachussetts
    sounds normal to me!..
    All of my trucks do that with the wheels cut all the way!--what your feeling is the tire slipping on sand or dirt when they are at such an angle..due to "Ackerman" effect,one tire turns at a sharper angle than the other--also the camber is extreme during a full lock turn,so only part of the tread makes road contact..plus 4wd's steer so sharply the tires go nearly sideways compared to a 2wd..my 4x4 can do a 180 where my 2wd has to take at least a 2 point turn!..so some slippage is normal..
    When your in 4WD,the front axle often feels like its grabbing and releasing if your turn the wheels on tar or packed dirt,due to the u-joints in the knuckles,they actually make the axle shaft speed up and slow down with every revolution..thats why other driveshafts usually have at least a pair of U-joints,to cancel out the variation in speed..
    Its possible a caliper or brake hose is letting one brake drag some ,and encouraging this to happen..jack it up and spin the wheels by hand,see if they feel stiff and hard to turn on one side..:crazy:
  8. JoeAngelicchio
    Feb 18, 2000
    628
    Thanks for the replies guys. I'll give it a once over just to make sure something hasn't worn out anyways. Couldn't find a Civic dangling under there so that's ruled out!!:rolleyes:
