slightly harder core: Of sliders and rocker boxes
Discussion in 'The Garage' started by dremu, Aug 21, 2005.
  1. dremu
    Feb 27, 2000
    15,968
    461
    East of San Francisco
    Stinking about sliders to replace the cheap and nasty nerf bars on my '74. (I bought those solely so my then-wife could get into the truck, so they're not useful any more :haha: )
    However, seems like the rocker boxes are in the way to attach damn near anything up there. I don't really wanna start a major project like boatsiding the damn thing this close to BlazerBash -- and I still gotta go buy and install a Detroit! -- so I was thinking sliders might do well.
    I saw DP90-whatever's stuff, looks nice (though he doesn't answer PM's or email, sniff, guess I should call :) ) ... but I presume I'd hafta :hack: the rocker boxes out to install them.
    Heck, if I'm gonna do that I can weld up some 2x4 or 2x6 square tube myself. :thinking:
    So, the question here: should I keep the rocker boxes, gut them, remove them entirely, what?
    The truck does have a full cage with good lateral support above the rockers, so that's a start. (And it has those nifty rubber handles :haha: )
    -- A
  2. 81jimmyslt
    81jimmyslt 1/2 ton status
    Jun 5, 2003
    1,643
    So Lake Tahoe (Rubicon), CA
    If your rocker boxes are rusted cut them out and weld in some 2x4" or 3". If your looking for something bolt on check out my site. I can also add steps if so desired. If you do gut them you might as well start boatsiding it too.
    Jesse
  3. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    I just cut mine out and replaced them with 2x2 box(weld in sliders from 4x4 iron. It was pretty easy(i had really good help) :D and i like it alot, ill post up pictures tonight
  4. GEORGIA GABE
    GEORGIA GABE 1/2 ton status
    May 25, 2005
    1,070
    Conyers, ga
    i welded up a set and attaced them just below the seam. they work really well.
    gabe
  5. sapper
    sapper 1/2 ton status GMOTM Winner
    Jul 11, 2001
    3,052
    NoVa
    These are pretty simple, bolted to the body mounts
  6. blazinzuk
    blazinzuk Buzzbox voodoo Premium Member GMOTM Winner
    Dec 20, 2002
    17,412
    3,799
    Afton / Star Valley Wyoming
    I cut them out and welded them to the floor and to the bottom of the rocker box mine is a 73 so it is the same as yours I used 3/16 3x3 welded them to the floor first ( kind of hard to do if you are an amutuer like me and then had a friend weld them to the bottom of the rocker box you need to do some prodding and pulling on them but it all works out and I have hammered on mine a couple of times
  7. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    remove the stock ones entirely, replace with some 3x2 or 4x2 rectangular tube. This adds ground clearance, unlike common bolt-on sliders or nerfs which take it away. It would also help make the cab more rigid / less flimsy.
    j
  8. dremu
    Feb 27, 2000
    15,968
    461
    Yeah, that makes sense ... but what didn't occur to me was the welding to the BODY, rather than mounting to the frame.
    You just put a tube along the outside wall and called it good, no reinforcement to the frame?
    -- A
  9. SkulzNBonz
    SkulzNBonz 1/2 ton status
    Feb 20, 2002
    4,522
    OKC, Oklahoma
    The ones I have, as well as the one's Daniel (DP90K5) fab up attach to the body stiffeners under the body. I have sat the truck down on one, and there was 0 damage. Mounted that way, they will support the weight of the vehicle. Pictures can be seen on my webshots site in my profile.
    John
  10. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    You are over thinking things. I have more than sat the weight of the truck on mine with no problems. It has fallen 2+ feet directly on to them, slit sideways at full lock, wedged through opening literally smaller than the truck, no problems. Cut out the rockers and weld in some steel. It works.
  11. MNorby
    MNorby 3/4 ton status Premium Member GMOTM Winner
    Dec 10, 2001
    6,127
    57
    Powell, Wy
    hope to not really hijack bot on the same note regarding sliders built into body on pickup truck. I made some sliders with some 3x2 last year and they attach to frame. Lately I have been thinking of boat siding somehow but with the seperation between bed and cab how would that work. Maybe do light boatsiding for clearance then move my frame mounted sliders up so can still slide from front to back tire.... Here are my current sliders:
  12. hi pinion
    hi pinion 3/4 ton status
    Sep 25, 2003
    5,354
    **PLUMBING THE WORLD**
    Just curious, but what bumper is that? That thing is sweet. Did you make it? :D
  13. jekquistk5
    jekquistk5 Weld nekid Premium Member GMOTM Winner
    Jan 18, 2004
    11,027
    855
    Pinckney, MI
    Yeah do tell. And I was just going to ask the same question
  14. hi pinion
    Sep 25, 2003
    5,354
    I like that bumper alot. Its probobly one of the best bumpers ive seen, its looks clean :D not too busy looking, i wonder if a winch could be had on it? :D
  15. stallion85
    stallion85 1/2 ton status
    Jul 11, 2003
    3,659
    Cedar City, UT
    I used 2X4 square tubing, 2X6 would be better I think the way I did it. I cut all the way to the weather stripping. It has held up great so far with big slams on them. I welded them onto the body.
  16. TrcksR4ME
    TrcksR4ME 1/2 ton status
    Feb 11, 2002
    2,482
    Seattle, WA 98103
    nice work there Stallion85, reminds me of how I did mine...
    I love my sliders, though I have not really used them persay...I put them up pretty high so I hardly have touched them with a rock :D
  17. stallion85
    Jul 11, 2003
    3,659
    Cedar City, UT
    Probably because you told me how to do it ;) :D
    Youre pic's really helped me when I did mine :wink1:
  18. TrcksR4ME
    Feb 11, 2002
    2,482
    Seattle, WA 98103
    :thumb:
    You certainly went to town on your Blazer when you got home! Glad someone got something out of one of my posts...for once :haha:
  19. GEORGIA GABE
    May 25, 2005
    1,070
    Conyers, ga
    I made both the front and rear bumpers on mine. The front bumper was made with an old driveshaft. I am working on a provision for a winch to mount behind the bumper and come through the front. I dont know what winch I am going to get yet so I dont know. Thanks for the complements.
    gabe
