Slip Yoke Bang?
Discussion in '1992-Present Chevy & GMC models' started by daleearnhardt01, Mar 28, 2007.
  1. daleearnhardt01
    daleearnhardt01 1/2 ton status
    Aug 29, 2002
    3,223
    Richmond, VA
    When I come to a stop sometimes I can feel the truck want to lurch foward, feels like Im getting hit in the rear a bit.
    Feels like a shudder of somekind more than a bang that would lead me to believe that its the slip yoke. Thought maybe it could be the convertor but keep it in second so it doesnt lock and it still does it. Trans shifts fine etc so Im thinking it has to be the slip yoke since its such a common problem. Im going to pull the shaft and drive in 4x4 to see..
    Any other ideas?
  2. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    sounds a lot like a slip yoke. Pull the drive shaft, grease the splines and the inside of the yoke and reinstall it. See what happens.
  3. ryan22re
    ryan22re 1/2 ton status
    Feb 5, 2005
    3,368
    Irmo, SC
    My 94 does that, I always thought it came from the drums, but now that you mention it, a slip yoke makes sense. At some point GM released a special nickel plated yoke, but it's way too expensive IIRC.
  4. daleearnhardt01
    Aug 29, 2002
    3,223
    Richmond, VA
    Yeah to the tune of $164.... So you thought it was your rear brakes too? Thats good alteast Im not crazy..
  5. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
    You are crazy...:D Just not about the slip-yoke dealy...:p: :D
  6. daleearnhardt01
    Aug 29, 2002
    3,223
    Richmond, VA
    Maybe just a little bit :o Im def not crazy about the shaft, that is driving me bonkers as is the wiper circuit board starting to go out...
    Driving in a hailstorm with no wipers is way fun :rolleyes:
  7. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    Check the ubolt tightness and the spring bushings also. If you have drum brakes and the adjusters are not equal, it can put the rearend in a bind because one wheel is stopping harder than the other. That tweaks the springs a little and the rear axle can get in a bind.
  8. daleearnhardt01
    Aug 29, 2002
    3,223
    Richmond, VA
    Yep plan on checking center pins and ubolts as well as the rear brakes just to be safe...
  9. ryan22re
    Feb 5, 2005
    3,368
    Irmo, SC
    I just cleaned the dust out of my rear drums and the noise went away. But mine is only 2wd. So...:dunno:
  10. daleearnhardt01
    Aug 29, 2002
    3,223
    Richmond, VA
    Yep I think mine was a sticky adjuster or something, after a few good high speed backups and brake applications it has stopped. I pulled the drums and everything looked okay in there. I greased the slip yoke anyways and found that one of the 4 bolts for the yoke straps was not even finger tight..
    Hasnt done it in over a week..
  11. 83ZZ502_Jimmy
    Feb 7, 2001
    3,103
    Richmond, VA
    That might do it....:D
