slip yoke clearance?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by elkboy, Jul 5, 2001.
  1. elkboy
    elkboy 1/2 ton status
    Aug 18, 2000
    293
    Hillsboro Oregon
    Does any one know what the stock clearance on a rear slip yoke is. I have 1-1/2 inches between the rear housing of my t-case and my driveline yoke. I'm not sure thats enough clearance under full compression and I think it's less than factory, but I'm not sure. I can test the length under droop, but not under compression.
    <font color=red> Elkboy </font color=red> 82 K5 fuel injected H.O.305, TH350/205, 14bolt/10bolt and 39.5 TSL's.
  2. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    Thats about right. Mine is 1 1/2 or damn near it.
    When in doubt.....Use the Saws-all[​IMG]
    <A target="_blank" HREF=http://www.nashvillek5.freeservers.com>http://www.nashvillek5.freeservers.com</A>
  3. jarheadk5
    jarheadk5 1/2 ton status
    Mar 6, 2000
    4,389
    PA
    I've never measured it, but I've been looking at the leaky-a$$ thing enough lately to say mine is exposed no more than 2". Stock (worn-out) suspension '87 K5, 31" spare in back, top on, 50lbs of tools, fluids & parts in back, 1/2 tank of gas. With these conditions, I have about 1 1/2" clearance between the bumpstops and the axle tubes. Hope this helps...
    If at first you don't succeed, failure may be your style...
    [​IMG] <font color=green>Semper Maintenance!<font color=black>
