Slip yoke eliminater
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by K5Junkie, Apr 7, 2000.
  1. K5Junkie
    K5Junkie 1/2 ton status
    Mar 29, 2000
    499
    Gulfport, MS
    Does anyone know where i can get a eliminater kit for a NP241 transfer case and about how much it may cost.
    Any help would be appreciated.
  2. Depdog
    Depdog 1/2 ton status Author
    1,657
    Georgia
    Not sure on the cost, probably be pretty expensive. Check out Tom Woods, if he does not have it, he may know where to get it. www.4xshaft.com Also here is another option. Get a second slip yoke and drill a hole in the center between the u-joint cap ends. Then drill and tap the shaft in your tcase for a small bolt. If you need to remove the rear shaft, slip in your modified one and bolt it on, wont fall off and will keep the oil in.
    Depdog
    <font color=blue>"Lead, Follow, or BECOME the Trail"</font color=blue>
  3. K5Junkie
    Mar 29, 2000
    499
    Gulfport, MS
    Thanks DepDog, that sounds like a pretty good idea
  4. Brian 89KBlazer
    Brian 89KBlazer 1/2 ton status
    779
    Ontario, Canada
