Slip Yoke Elimination
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by DesertDueler, May 24, 2001.
  1. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    Does anybody know of a kit that eliminates the slip yoke on a NP-208? If so where can I buy one?
  2. Sparky87k5
    Sparky87k5 1/2 ton status
    May 6, 2001
    726
    Lynden, Washington, 4 miles from Canada
    I did a search on this subject and found all kinds of info. Give it a try, you find the answers.
    87 K5, D60 & 14FF, 5 sp & NP208 & 383 stroker. Build it Bulletproof and take it fishing!
  3. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    Sure!
    The kit is called.... an NP205!
    Seriously, I don't think it exists. If you need that little extra low-range, the NP241 from an 88-91 Blazer/Jimmy/Sub will accept a JB Conversions SYE kit.
  4. ScoobyDann
    ScoobyDann 1/2 ton status
    Mar 9, 2001
    305
    El Paso, TX (Far West Texas near Las Cruses
    Ive heard you can take the front of the chevy 208 nad the rear of a dodge 208 and put the 2 togather adn there you go..my question is can you find someone that has done this?
    <A target="_blank" HREF=http://jimjim.coloradok5.com>http://jimjim.coloradok5.com</A>
  5. mpascino
    mpascino 1/2 ton status
    Jan 1, 2001
    557
    Connecticut
    did the dodge/ chevy thing. As long as you get the correct spine count dodge setup it's pretty straight forward. I had to open open three T-cases though before we found the correct match. For what's it's worth it's in the best of interest to go the 205 route though. I remember being told no one solds a fixed yoke kit for the NP208C.....
    You call that dirty!?
  6. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    Would the 241 kit work in the 208? Seemd like they would as similar as they are
    My president is Steve Fox.
    90-350TBI-TCI700-241-33"-10 bolts w/4.10's,
    <A target="_blank" HREF=http://www.nashvillek5.freeservers.com>http://www.nashvillek5.freeservers.com</A>
  7. FRIZZLEFRY
    FRIZZLEFRY 1/2 ton status
    Apr 20, 2001
    3,271
    134
    Clovis CA
    I saw a post from a couple months ago by Iceman that he did this .He used a Ford 208 to do this.He used the output shaft from the ford and the tail housing.He redrilled the chevy 208 case so he could bolt on the ford tail housing.I think he had to modify the shifter also.It didnt sound all that bad.I saw another post by a guy that did the same thing and he said he got it together and it worked but the t case didnt shift right.It sounds like a great idea if it works.I just found where I saw it .Its on a post from 3/4/01 by super bee.Iceman on there gives a good idea of what it takes.
    All work and no beer makes Frizz a dull boy<P ID="edit"><FONT SIZE=-1>Edited by FRIZZLEFRY on 05/25/01 09:48 AM (server time).</FONT></P>
