Slip yoke eliminators
Discussion in 'The Garage' started by yellowK20, Nov 13, 2003.
  1. yellowK20
    yellowK20 Well Lubricated Premium Member GMOTM Winner
    Dec 26, 2002
    7,609
    559
    Wasilla AK,
    Were can I find a slip yoke eliminator for a 90' model NV-241 ????? who's used them can they be installed with the t-case in the truck???????
  2. marv_springer
    marv_springer 1/2 ton status
    Aug 3, 2001
    2,781
    Mesa, Arizona
    Brian LaBarge(ck5 name "LaBarge") has installed one on his 241. Might PM him....
    Marv
  3. Fubeca
    Fubeca 1/2 ton status
    Dec 18, 2002
    2,100
    Denver Area
    Check out www.highangledriveline.com, I got mine there. I don't think you can install it with the t-case in the truck, you pretty much have to take the case all apart.
  4. Masher
    Masher 1/2 ton status
    Mar 7, 2002
    123
    SW Michigan
  5. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    In the Burbs close to Tulsa, OK
    I have abused mine for the last 2 years or so with no problems. I got it from High Angle and installed it myself. I would not attempt to install it with the case in the truck. It only takes about 20-30 minutes to drop it out of the truck and it weighs less than 100 lbs.
  6. TxK5Blazer
    TxK5Blazer 1/2 ton status
    Aug 13, 2000
    593
    Floresville, Tx
    would this work for a 208 also or does someone make one for a 208.....Jason
  7. yellowK20
    Dec 26, 2002
    7,609
    559
    Wasilla AK,
    link didn't work how much are they ????
  8. Fubeca
    Dec 18, 2002
    2,100
    Denver Area
    The link is to the homepage, if you scroll down a little there is a link to the short shaft kit page the url is http://www.highangledriveline.com/231_short_shaft_kit.htm
    I think Jesse gets his kits from JB, I bought from him after reading that someone got some incorrect parts from JB. He was cheaper too - even after shipping.
  9. yellowK20
    Dec 26, 2002
    7,609
    559
    Wasilla AK,
    my computer must have down syndrome that link won't work either /forums/images/graemlins/angryfire.gif
  10. Chris Demartini
    2,406
    Dumont NJ 07628
    I got mine from JB Conversions, real nice kit. Check it out here: http://www.jbconversions.com/pages/np241/index.html
    /forums/images/graemlins/thumb.gif
    <font color="blue">The JB page shows a Jeep and a HD truck version, what's the difference?
  11. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    Sadly no one makes a 208 version. You can convert the guts from your 208 with guts from a Dodge 208 with no slip yoke. I am just going to hunt down a 241 and put that under my K5 and High Angle SYE kit. Want to eliminate the Slip yoke and a little lower ratio is always welcome.
  12. Scott A
    Scott A 1/2 ton status
    Apr 18, 2002
    129
    Monrovia, CA
  13. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    yes those SYEs exist for the 208 but its a cheap crappy way of doing it. It doesn't shorten the overall length of the case at all either.
  14. VisionxOrb
    VisionxOrb 1/2 ton status
    Oct 10, 2001
    251
    Newbury Park, Ca
    which part is crappy.... the only real negative thing ive heard about these is that people have busted or twisted a shaft, havent heard any bad the flange it self which is the only special part in this whole thing.
  15. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    The 241 SYE has a bearing in the output housing at the end of the shaft. That 208 SYE wannabe uses the stock output housing that uses bushings. The reason people are busting shafts is two fold, one their drilling, thus weakening the shaft, and two, there is no additional support at the end of the shaft. Oh, and your actually lengthening the output shaft by adding the bolt on yoke. This causes more leverage too.
  16. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    What he said, I really have no idea what I'm going to do in the K5. I can't afford a doubler and don't want the weight of one but locating a 241 that will bolt behind my 465 is looking like a very daunting task.
  17. VisionxOrb
    Oct 10, 2001
    251
    Newbury Park, Ca
    well i ment busting shafts as in drive shafts not output shafts but anywho not important i guess.
  18. jarheadk5
    jarheadk5 1/2 ton status
    Mar 6, 2000
    4,389
    PA
    Uhh, YES there's a HUGE difference between those 2 scenarios. With a broken rear driveshaft, you can replace it with your trail spare (you've got one, right???) and keep on truckin', or just pull it entirely and limp home in front-wheel drive. /forums/images/graemlins/wink.gif If you break the output shaft of the T-case, there's liable to be other damage inside the case, like fragments... Get one decent-size metal chunk run thru the gears and kiss the entire T-case goodbye. /forums/images/graemlins/eek.gif And even with as anal about trail spares as some people on this board are, I don't think ANYONE carries a spare T-case with them....... /forums/images/graemlins/thinking.gif /forums/images/graemlins/thinking.gif
