slip yoke for 241 and 208- are they the same?
Discussion in 'The Garage' started by COCHEV, Jan 18, 2003.
  1. COCHEV
    COCHEV 1/2 ton status
    Jul 9, 2002
    4,055
    Washougal WA
    want to use a rear drive line that i have the goes to a 208 and use it with a 241 case. will it slip in?
    jason
  2. 87sm465np208
    87sm465np208 1/2 ton status
    Aug 28, 2002
    1,114
    illinois
  3. ZonkRat
    ZonkRat 1/2 ton status
    Jan 16, 2003
    1,003
    Lawrence County Tennessee
    The 205 with a slipyoke uses a 1350 series joint an will work with 241 T-case.Found this by chance when i blew a ujoint on mine.Couldn't find stock yoke,but,a good friend had spare parts for his Sub and {suprise} gave it to me.Sometimes you get lucky /forums/images/graemlins/crazy.gif /forums/images/graemlins/truck.gifer in TENN. Almost forgot,some 400 turbo yokes will also work,just make sure it has full splines.Most are only half length inside.Hope this helps,took me nearly a month to find out.
  4. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    NP208 and NP241 use the same slip yoke. So your answer is YES it will work.
  5. COCHEV
    Jul 9, 2002
    4,055
    Washougal WA
    ok, now i have 2 different answeres. /forums/images/graemlins/tongue.gif anyone else care to comment?
  6. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    Yes your drivshaft slip yoke from the 208 will slide right in on a 241. That's one of the reasons I reccomend swapping from a 208 to a 241 is because you will not need new shafts. /forums/images/graemlins/thumb.gif
  7. 4x4Freak
    4x4Freak 1/2 ton status
    Apr 21, 2002
    792
    Lubbock, TX
    The 208, 241, and 205 will all accept the same slip yoke. The main differences may be the ujoint size. My brother swapped the t-case out of a 91 suburban into his 82 K10 and used the driveshaft from the 208. I then used the driveshaft out of the suburban and put it on my 205 in my K10.
