Slip Yoke For a NP208
Discussion in 'The Garage' started by blackblazer717, May 12, 2006.
  1. blackblazer717
    blackblazer717 1/2 ton status
    Jul 1, 2004
    470
    massachusetts
    i need a new rear slip yoke for a np208 with 1/2 ton u-joint, any help on a source would be great, i dont have the money right now to swap out case or go to SYE so any help would be awesome!!
    i absolutely destroyed my old one and tore the ears off of it!
    thanks!!!
    LUKE
  2. blackblazer717
    Jul 1, 2004
    470
    massachusetts
  3. 87BrnRsd
    87BrnRsd 1/2 ton status
    Apr 21, 2003
    2,457
    Boone, North Carolina
    Go to a junkyard, cut the slip yolk off of one there, then have a driveshaft shop weld it on your shaft.
    -Harrison
  4. drivelineman
    drivelineman 1/2 ton status
    Aug 23, 2000
    707
    I may have a used one if you can't find one- Jess
  5. blackblazer717
    Jul 1, 2004
    470
    massachusetts
    that makes no sence because the slip yoke isnt welded to anything...... its held to the shaft by a u-joint, NOT a weld..... you must be really confused...
    LUKE
  6. 87BrnRsd
    Apr 21, 2003
    2,457
    My mistake man...I have a slip yolk rear shaft with a cv joint on my 208, and for some reason I thought you meant the whole thing.
    Either way man, why dont you just go to a junkyard and get one??????????????? :confused: :confused: :confused:
    -Harrison
