Slip yoke leak
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by joker89blazer, Nov 11, 2002.
  1. joker89blazer
    joker89blazer 1/2 ton status
    Nov 21, 2001
    130
    panama city florida zip 32409
    The cap at the back of the slip yoke that keeps the atf from leaking out the back of the slip yoke. Mine has been repaired with jb weld once from the backside and is leaking again.Can the plug be knocked out of the yoke and then coated with jb weld before reinstalling? I would think this would be better than putting jb on the outside are the inside of the yoke. Would the cap are the yoke get damaged by removing the cap. Anyone try this? /forums/images/graemlins/rolleyes.gif
  2. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    Yes knock it off and re JB weld, and I would put some RTV in to make sure there is no leaks, it's soft pliable and will not crack. /forums/images/graemlins/thumb.gif
  3. joker89blazer
    Nov 21, 2001
    130
    Thanks for the reply. I'll try that or braze it on. Scared welding might destroy the balance [I'm a bad,bad,bad welder! /forums/images/graemlins/eek.gif]
