Slip Yoke?
Discussion in 'The Garage' started by Suffergauge, Nov 14, 2002.
  1. Suffergauge
    Suffergauge 1/2 ton status
    Aug 1, 2002
    153
    Olympia, Wa.
    Okay so I am gonna sound like a retard here but what is a slip yoke? I hear tons of bad stuff about them. Is it where the driveline kinda looks like there is a shock in the middle of it? How exactly does the eliminator kit work?
    Thanks,
  2. georgiared84
    georgiared84 1/2 ton status
    Sep 5, 2002
    487
    Austell, Georgia
    On the back of NP 208 transfer cases the yoke that the drive shaft attaches to the transfer cases with is a free floating shaft wich engages to the transfer case with splines and the drive shaft with a yoke and single u joint. If the drive shaft were out, the slip yoke can be pulled right out.
  3. Suffergauge
    Aug 1, 2002
    153
    Olympia, Wa.
    So I am assuming that I don't have one because the yoke on the back of my t-case is bolted on. So what is the one like mine? It looks like it extends and contracts somehow.
  4. 4x4Freak
    4x4Freak 1/2 ton status
    Apr 21, 2002
    792
    Lubbock, TX
    If your truck is older than '80 then it will have a fixed yoke, with a slip joint on the driveshaft itself. In 80 or 81 they started putting the slip joint on the transfer case, with a solid driveshaft.
  5. georgiared84
    Sep 5, 2002
    487
    Austell, Georgia
    I don't know if yours is still visible but if you look at the rear of your transfer case, You should see a little tag with something like New process 205, etc... If you don't have a slip joint, that's actually good. There's quite a few here who have paid good money to change them over to what you've got.Yours is called a fixed yoke. Right behind it you should have a cv joint and lower on the shaft you should have a slip joint and then your rear u joint. That's the same setup I've got on my paperweight of a chevy 4x4 shortbed.
  6. 4x4Freak
    Apr 21, 2002
    792
    Lubbock, TX
    Not unless it's been modified. In stock form it should be just a plain ujoint.
  7. georgiared84
    Sep 5, 2002
    487
    Austell, Georgia
    I can't tell from mine what was stock. I don't think much on it is.
  8. Suffergauge
    Aug 1, 2002
    153
    Olympia, Wa.
    It goes - np203 w/ a fixed yoke, u-joint, slip joint, u-joint, diff.
