Slipping Out of 4 Wheel Drive
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BIGBIRD, Jul 31, 2003.
  1. BIGBIRD
    BIGBIRD Registered Member
    Apr 17, 2002
    21
    North Carolina
    I've got a '75 Blazer whith what I believe to be the stock transfer case, has a slip joint in the drive shaft, anyway when you start bouncing around a little she slips out of 4 wheel drive. In both hi and low. Are there any adjustments that can be made, of am I headed for a rebuild ?
  2. Calclips
    Calclips 1/2 ton status
    Apr 4, 2001
    1,005
    Swartz Creek, Michigan/Flint while in school
    Is your body rusted up and flexing on the frame? If your body mounts are bad and the blazer tub gets rocking around, it can pop it outta gear.
  3. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    The shifting forks are probably bad. thats kinda weird it slips out of 4 low, that is a pretty stiff gear. Mine slips out of 4 hi only when things get bumpy. Mine is an np208 and may be different inside than your 203 though. You are looking at a rebuild, sorry.
    85k5 3/4ton,14bolt,10bolt,9"lift,35"boggers,16.5x14welds, big horse 406SBC/700r4 /forums/images/graemlins/k5.gif /forums/images/graemlins/angryfire.gif
  4. CaveBlazin
    CaveBlazin 1/2 ton status Premium Member
    May 21, 2002
    1,348
    Middle TN
    What part of NC you coming from maybe one of us NCK5ers can swing by and help ya...
  5. BIGBIRD
    Apr 17, 2002
    21
    North Carolina
    Wilmington. Use it mainly on the beach but get in the mud some.
  6. BIGBIRD
    Apr 17, 2002
    21
    North Carolina
    It will stay in 4 wheel if I keep light pressure on the shifter. Could it be that i'm not getting it all the way ingaged since both the high and low 4 wheel selections are at opposite ends of the shift pattern. Is the shifter adjustable at all ?
  7. rampage
    rampage 1/2 ton status
    Mar 20, 2001
    2,261
    74
    Humboldt/Pacifica, CA
    If you have a body lift the shifter will hit against the floorboard popping it out of gear. Pull the cover off the shifter and see how close it is to the floorboard. If it's hitting then you need to cut some sheetmetal.
  8. BlueKnight
    BlueKnight 1/2 ton status
    Mar 6, 2000
    1,518
    Oregon
    Mine did this on a club run of ours awhile back. Rob and I spent like and hour digging out tree limbs and mud and debris from under the truck and the lubed the linkage back up. seems to work. I do have a body lift and had to cut a small channel for the shifter.
