slipping out of 4wd
Discussion in 'The Garage' started by digity, Feb 10, 2007.
  1. digity
    digity 1/2 ton status
    Oct 10, 2004
    184
    13
    Brentwood Ca
    My Jimmy keeps slipping out of 4wd and the shifter itself dosent really lock or click into 4wd I'm sure it can b a number of things but r ther a few checks I can do to rule things out? Its a 90 just did 3/4swap n 6in lift. Also lowered the tcase 1in Im wondering if tht tweaks things a bit? Any suggestions?:doah:
  2. resurrected_jimmy
    May 23, 2005
    2,241
    back home in Houston
    adjust your shift linkage and check for interference between shift lever and floor
  3. Mr.Jimmy
    Mr.Jimmy Registered Member
    Nov 20, 2006
    66
    Albuquerque, NM
    what t-case u got? My first 208 was doing that and it got so bad i pulled it and put in a used one i found at a decent price. since ive swapped, the problem hasent reaccured. My truck has a 3" body lift and my shifter works fine. you could drain the fluid and check for metal shavings, that will at least tell you what shape your in. good luck bud
