slipping tranny
Discussion in 'The Garage' started by shaun, Apr 11, 2005.
  1. shaun
    shaun 1/2 ton status
    Apr 22, 2003
    745
    I just placed a supposed rebuilt 400 and it slips. Som B***h. Is there anything I can do to try and fix this w/o pulling the tranny
  2. dyeager535
    26,982
    191
    Made sure its full of fluid after you started the engine and ran through all the tranny gears?
  3. shaun
    Apr 22, 2003
    745
    I did that
  4. matto
    matto Registered Member
    Feb 20, 2005
    49
    uncasville ct
    how bad does it slip. my th350 needs to be rebuilt but i put in anti-slip trans fluid and it made a huge difference. you can try that but if it is real bad i am not sure what to do.
  5. louied
    louied Registered Member
    Mar 19, 2002
    84
    Philadelphia
    try some Lucas Trans Additive! IT worked for me !
  6. diesel4me
    Jul 24, 2003
    17,577
    945
    Massachussetts
    Make sure..
    Check the modulator valve,and make sure it has good vacuum at its hose when engine is running--a bad modulator valve will have tranny fluid on the hose connection side if its diaphram is ruptured...and that will reduce the line pressure to the clutches,and let them slip...also a partially blocked filter can cause silppage too,or one that has a missing or broken gasket can too..but there is always the possibility something was not done right during the rebuild also...hope not.. :crazy:
