Slipping trany
Discussion in 'The Garage' started by BNeu, Jul 11, 2006.
  1. BNeu
    BNeu Registered Member
    Feb 9, 2003
    12
    Would loose tranny bolts cause my tranny to completly slip into 3rd?:confused: just was about to pull it and all that i can reach with my hand are finger loose.
    Also im getting a 91 K5 and wanted to know if the transfer case is the same as out of a 90.
    Bryan
  2. slider
    slider 1/2 ton status
    May 7, 2001
    547
    Whidbey Is. Washington
    automatic or manual???????? And for the transfer case question as long as its the same case (eg np208) it should bolt up. If the trans is an automatic loose bolts will not cause slipping.
