Slips outta 4wd
Discussion in 'The Garage' started by stockk5, Aug 29, 2005.
  1. stockk5
    Apr 13, 2004
    2,037
    73
    Cromwell, CT
    Sometimes when i am in 4HI it falls out into 2wd, i wont notice it for a few seconds but its getting kinda annoying if im going over really bumpy stuff in 4hi it does this. How come? how can i fix it?
  2. adamforsythe
    adamforsythe 1/2 ton status
    Oct 16, 2004
    1,394
    Maine
    You need to adjust your linkage.
  3. k5freak44
    k5freak44 1/2 ton status
    Jun 1, 2004
    2,164
    Plano, TX
    get warn hubs, and it wont slip out again
  4. stockk5
    Apr 13, 2004
    2,037
    73
    Cromwell, CT
    i have warn.. its the tcase that falls into 2wd
  5. RustBuket
    RustBuket 1/2 ton status
    Feb 21, 2003
    1,618
    Saskatchewan, Canada
    Mine did the same thing. Wouldn't even stay in 4 HI at all until I adjusted the linkage and then it worked.
  6. stockk5
    Apr 13, 2004
    2,037
    73
    Cromwell, CT
    hm ok how do i adjust the linkage? i havent really check it out under there yet..
  7. K5er4Life
    K5er4Life 1/2 ton status
    Oct 16, 2002
    1,456
    Bellflower, Ca
    what kind of t-case do you have. If it is a 208 then I would agree it is the linkage, I had the same problem with mine. But if its a 205 then its usually the shift rails that get worn out.
  8. midnitewarya
    midnitewarya Sounds like a problem for future me. Premium Member
    Dec 1, 2002
    1,726
    20
    SoCal
    Adjusting the linkage
    Just above your transfer case you should see a shifter arm coming out of the T-case housing. On this arm there is a threaded bolt with a c-clip or some other type op clip holding it in place. Undo all of that linkage so that the t-case is no longer conected to the shifter. Put on your e-brake and then set the shifter to 4HI. Go back under the truck and set the shifter arm to 4HI. (This is one "click" back from all of the way fowards) Reattach the the linkage making sure that the shifter does not move and the linkage arm does not move. That should do it. This is a common problem if you've dropped your t-case due to a lift.
    Al
