slipyolk cv shaft $$?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 1990K5, Jul 7, 2001.
  1. 1990K5
    1990K5 1/2 ton status
    Nov 6, 2000
    460
    LITTLETON CO.
    i know i should do a 205 conversion but i really like the low range on my 241plus it is newly rebuilt w/ a 40k warrr. the tail shaft conversion is way $$$. when you let off the gas on my blaze it starts saying things that would make a sailor blush, ive batteled this problem for 2 yrs. now, rebuilt the t- case ( for no reason, did'nt help) rebuilt the 12 bolt, got rid of blocks for a shaclke flip, lengthened/shortened drive shaft, tried traction bars and tried different shim angles. i dont know what else to do. i heard of the c.v. slip yolk drive shaft, is there any donor vehichle that would have somthing like this that i could use atleast part of the keep the cost down? or how much is a new one? thx--j.c.
  2. CaptCrunch
    CaptCrunch 1/2 ton status
    Feb 2, 2001
    3,596
    Minnesota
    I've heard of guys using ones out of Caddys or something, but I say to heck w/ that. I'm pretty tired of trudging and wasting weekends going through our picked clean salvage yards... I got mine from Tom Wood's driveshaft for $325 shipped to my door. Jess also makes one ton shafts at High angle. I would personally go w/ the tailshaft conversion kit though... waiting for one for my 208.
    -Mikey
    1987 Chevy K5 Blazer- 350 TBI
    <A target="_blank" HREF=http://www.geocities.com/milnerlives_2000/blazer.htm>http://www.geocities.com/milnerlives_2000/blazer.htm</A>
  3. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Jesse won't make you a slip yoke CV shaft. He doesn't feel it's reliable so he won't put his name on it or sell it.
    Tim
  4. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    Are you sure that Jesse has stopped selling them?
    A monthe ago, I had one scheduled but after talking with everyone I will be going with the slip eliminator for the 241.
    Do it once and never have to worry.
    Dave
    Beauty is in the eye of the beer holder.
  5. moneypit
    moneypit 1/2 ton status
    Sep 3, 2000
    1,382
    COLORADO
    Been there done that! The only way you will make it right is with a cvshaft. There are quite a few places to get them it just depends on what you want to pay. The cv shaft is the only way to get your k5 to shut up. I got mine from high angle. I believe Tom Woods sells a cv shaft that is very stout yet affordable for most. Good Luck.
  6. 1990K5
    Nov 6, 2000
    460
    LITTLETON CO.
    whats unreliable about a c.v. shaft?
  7. 1990K5
    Nov 6, 2000
    460
    LITTLETON CO.
    does anybody know anything else on this caddy shaft captcrunch is talking about??
  8. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    It is the CV joint that they use when you don't go the SYE and 1 ton stuff (I think).
    Jesse has a few recent posts with explanations on this exact subject.
    Dave
  9. RGF
    RGF 1/2 ton status
    Jan 5, 2001
    281
    Maine
    I used a caddy driveshaft a few years ago on a 90K5 that I had, after putting in a D-60/14bolt-4:10gear and lifting it 2 1/2" I had some vibration starting around 50mph.I tried everything to get rid of it, took the 1350 shaft that I had shortened and balanced back twice to check and it still was there. Got a caddy shaft from the junkyard and had it shortened and balanced with the 1350 end on it,also had a 6degree shim made and put it in the spring pack.After all that work it now vibrated at 60mph and I lived with it until I sold the Blazer about a year later, also I dislike longtail transfers in short wheelbase trucks.
    The bad part about those caddy shafts is the lenght of the slip, they are alot shorter than the truck shafts and to make matters worse if you look in the end the splines dont even start until like half way down so you end up with very little spline contact.Not a very good thing for wheeling but would probably be OK for street driving.
    RGF
  10. 1990K5
    Nov 6, 2000
    460
    LITTLETON CO.
    thx for the reply, could you put the stock slip end on the caddy shaft w/a bastard u-joint?
  11. Jeff427
    Jeff427 1/2 ton status
    May 22, 2000
    1,186
    Gladwin, MI
    Just contact Jesse, at High Angle Driveline and get a slip yoke eliminator kit, then you can run a one ton CV.
    forwhlr@saber.net or call him at 530-877-2875
    Jeff427
    <A target="_blank" HREF=http://muddog.off-road.ws>Mud Dog Off Road Club</A>
    <A target="_blank" HREF=http://lyonsdesign.bizhosting.com>Lyons Design Web Site</A>
  12. RGF
    RGF 1/2 ton status
    Jan 5, 2001
    281
    Maine
    You cant put the stock slip on the CV caddy shaft, completely different set-up.I know your trying to save some bucks, arent we all but the right way to solve your problem will cost some $$$.
    RGF
  13. newyorkin
    newyorkin 1 ton status
    May 8, 2001
    16,555
    157
    Los Estados Unitos
    My dad has been driving/modding caddy limo's all my life. He just recently retired his last one, but has tons of parts.
    The limo driveshafts are super long and have cv joints in the middle. I was thinking about looking into one of these for my truck. My objective would be to have as much slip-yoke inside the t-case as possible with room for flex, then down to the rear via CV joint. I guess I'll still look at it, but with less hope than before, after reading this post. Bummer.
    Capt, was it you that said you put a new slip yoke on and it was a huge difference in clunk?
    Ratch
    <A target="_blank" HREF=http://k5.8m.com>http://k5.8m.com</A>
    **K5 - What more is there to life?**
  14. CarolinaBogger
    CarolinaBogger Registered Member
    Apr 17, 2000
    86
    Boone, NC
    How much money/work does it take for a slip yolk eliminator for a 241?
    CB
  15. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    -Complete tear down of the 241
    -SYE kit
    -new driveline
    so - labor on an app 4-8 hour job plus the parts (call your preferred dl manufacturer for that)
    Mine is being done so I can give you some real numbers in a few weeks.
    Dave
  16. CCRider
    CCRider 1/2 ton status
    Jul 8, 2001
    314
    Charlotte North Carolina
    Slip yoke eliminator from jb conversions was $325.00 w/no yoke yoke was 69.00 from denny's driveshaft.com , rear cv shaft from denny's (very reputable) was $325.00 . Totally eliminated my vibes!!! fixed yoke now , no leaks! Check out Denny's site though! SYE kit took me 3 hours total from time I drove in the garage til the time I drove out! Shaft too!! Good Quality stuff all around and am very happy with !
  17. CarolinaBogger
    Apr 17, 2000
    86
    Boone, NC
    dang! that SYE change-over sounds a little too far out of my budget right now. However, I am getting ready to put a 8" lift on and was checking out the driveline places like Denny's and Tom Woods, and High Angle. In ya'lls opinion, which one of these shops would be my best bet if i were to go with a CV driveshaft with the slip yolk? Or, do ya'll think i really should wait and do the 241 SYE conversion?
    'Thanks
    CB
  18. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    Do the conversion. Every reason to do it other than high $$$$.
    Don't know the other shops but Jesse at highangle is cool and contributes here on these forums.
    Dave
  19. CCRider
    Jul 8, 2001
    314
    Yes it's kind of pricey$$ , but you gain 6" extra length in shaft , if you break a joint or damage a shaft , you can remove it and drive on just the front (hell I did for 2 weeks after installing the kit!!) and gets rid of that damn slip yoke!! i just think those things are trouble , I tried for 3 years to get rid of my vibes , and got close, but NONE with the kit!
    1991 Fullsize 5 1/2"lift, 37"ssr's,10Bolt8 lug , 14Bolt ff, 4:56 Detroit rear, 12"fr. 14"r Bilstein remote res.350 P.F.I , 700r4 , 241c W/ sye
  20. 1990K5
    Nov 6, 2000
    460
    LITTLETON CO.
    [censored] that over $700 worth of work!!!! i could just swap in a 205
