slop in the steering
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by aj_tatted, Nov 6, 2003.
  1. aj_tatted
    aj_tatted 1/2 ton status
    Sep 6, 2003
    183
    arlington, tx
    how do i adjust out the slop in my steering? someone said something about putting a brace on the box. hmmm?how do you guys do it?
  2. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    first you have to check that that is the problem/cause,
    it can be anything from worn out rod end, to loose steering box, to cracked frame to worn out box, to who knows what, you will need ot get under truck and watch parts as someone quikcly whips steering wheel back and forth about 4" of travel with truck not running.
    watch for side to side movement of pitman arm shaft of box, and for box movement away or against frame rail, IE loose bolts or cracked frame rail.
  3. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
    The common problems are:
    Problem:Worn Tie-Rod ends
    How to Check: Raise front of truck, grab a front tire on the fore-aft axis, wiggle and watch for tie-rod slop
    Problem: Ball Joint Wear
    How to Check: Raise front of truck. grab a front tire on the up-down axis, wiggle and watch for ball joint slop. Lower truck, watch for any movement in ball joint slop as weight is transferred onto wheels from jack.
    Problem: Loose Front Wheel Bearings
    How to Check: Same as for the ball joints, but the tire wiggles too much and you don't see the play in your ball joints, your wheel bearing require adjustment for replacment.
    Problem: Drag Link Wear
    How to Check: Raise front of truck. Have a helper turn the steering wheel back&forth while you hold on to the front drivers tire, watch for slop in the drag link. Also grabbing the drag link with your hand and wiggle can show the wear sometimes too.
    Problem: Loose Collapsable Steering shaft
    How to Check: Get two pairs of vice grips, clamp one pair on lower section, one pair on upper section, grab both pairs and attempt to wiggle in opposite directions. If ANY play is detected, replace the shaft. This is the most overlooked piece of the steering system and usally is the second most common cause of loose steering on these trucks.
    Problem: Loose Rag joint
    How to Check: This isn't as common. Raise front of truck. Have a helper turn the steering wheel back and forth while you watch the rag joint. Look for play.
    Problem: Cracked Frame
    How to Check: With truck on ground, have a helper turn the steering wheel (Truck can be running for power assist) and look for frame wiggle in the area of the steering box. Also, with engine off, simply inspect the frame around the steering box. Cracks usally show up on the top of the frame rail and just infront of the forward bolt holes (hidden, unless you can weasel of look at the inside/back side of the frame rail, which usally requires a mirror)
    Problem: Spring fasterns/bushings/mounts
    What to do: Tighten your spring and axle fasteners, they may be loose. Check for bad spring bushings front & rear. Check the sway bar bushings as well. If you've put lift blocks on our front axle, remove them, they are dangerous and illegal in most states and a very likly cause of loose steering.
    Myth about steering box adjustment:
    There is a common myth that adjusting the allen bolt on the top of your steering box will tighten steering. This is just a myth. What is will do is place more preload internally on the sector shaft and cause you to have to put more effort into turning the wheel (More torque required to turn). It will not remove any "play" from the system. If you have sloppy steering or the truck is wandering and tough to control, adjusting this WILL NOT help you at all. Additionaly, if you adjust it improperly, and place too much pre-load on the sector, it will break, leaving you without steering, and in a potentially very bad situation. People like to belive this myth because it is easy and free. But it won't help with sloppy steering. So avoid it. Adjusting this properly requires removing the box and putting it on a "tool" or machine that will tell you exactly where the pre-load should be. It is adjusted at the factory and requires no furthur adjustment.
    Ken
  4. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    Ken
    yep, if the box adjusting bolt has to be adjusted, then it simply means that the box has alot of wear in it and for safety reasons should not be adjusted very much- if at all- and should be replaced
    my 83 has some slop in the steering and i am hoping its not due to internal box wear,
    i have yet to lift front of truck off ground and inspect to see where slop is coming from
    i hope its like wheel bearings or a rod end or loose box bolts or soemthing dumb like that /forums/images/graemlins/laugh.gif
    most likely is since truck appears to never been abused. it drives great otherwise
    getting weight off the front wheels is the way to check for incorrect movement of parts, IE wear.
    good luck
