Sloppy Shifter
Discussion in 'The Garage' started by jacob_coulter, Nov 14, 2006.
  1. jacob_coulter
    jacob_coulter Registered Member
    Jun 28, 2005
    12
    USA
    Is there an easy way to re-align the automatic transmission column shifter to point at the right gear.
    My shifter pointer is way off, and I have to "feel" my way to find the right gear.
    The shifting action also feels sloppy, Like a stick in molasses, not firm and tight.
    Is this easy to fix, or should I go to a tranny shop and let them fix it?
    Thanks for the help
  2. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,992
    130
    I believe it has to do with your shift cable stretching of being out of adjustment. I have almost no experience with auto Chevy's but I would imagine that is a pretty easy fix.
  3. MattK
    MattK 1/2 ton status
    Jan 12, 2005
    1,713
    Dallas, TX
    im not sure about fixing the actual feel of it. i think trucksas old as some of ours just dont have the greatest feel to em.
    now the indicator is a pretty easy fix. i believe you remove the dash bezel and you'll see a small metal clip on part of the of top of the steering column that has a small string running from it to the indicator mech. just slide it over one way or the other to adjust.
  4. ryoken
    Jun 13, 2003
    29,622
    1,375
    Jersey Shore
    Easy fix, ditch the column shift and get a real shifter... :wink1:
