Slow cranking starter blues
Discussion in 'The Garage' started by 70jimmy, Nov 21, 2006.
  1. 70jimmy
    70jimmy 3/4 ton status Premium Member GMOTM Winner
    Mar 3, 2000
    5,953
    248
    Released from Pueblo, told I belong in Southpark
    O.K. History: Just put in a 350 SBC bored .060 over, heads redone, new valve springs, lifters, cam etc. It is carbed and has HEI. Drove jimmy in garage swapped motors and some parts put back together and slow cranking starter. I have put 3 starters on and still same problem. I havent even had it running yet.
    Ran some tests with voltmeter: Negative lead on voltmeter to negative battery post and positive on meter to S terminal on solenoid. A little over 9 volts when cranking.
    Negative on meter to engine (ground) and positive on meter to solenoid strap on starter motor. 12 volts when cranking.
    Negative on meter to negative battery post and positive meter lead to starter body. less than one volt when cranking.
    battery is around 13 volts before and after tests.
    Positive battery cable at starter is battery voltage 13 or so
    battery wire at dizzy cap is 12 volts
    wires replaced that come out of fuse block and go to dizzy and starter
    fuses replaced in fusible links and checked with voltmeter OK
    Distributor gone thru and all working properly many things replaced.
    Any ideas???? Thanks
    I have checked the wiring diagrams and all seems proper.
    Does anybody have any leads from the negative cable that go anywhere??
    I do have grounds from body to frame, frame to motor.
  2. mostwanted
    mostwanted 1/2 ton status
    Feb 5, 2006
    765
    Kansas City, MO
    take your battery to have it tested. I had a bad battery that would show 12volts, but wouldn't crank the motor. I had it tested and it failed.
  3. 70jimmy
    Mar 3, 2000
    5,953
    248
    Thanks, That thought came to me this morning. I wake up BATTERY!!
    Now my wife thinks I'm really wierd.
  4. opfor2
    opfor2 1/2 ton status
    Oct 28, 2002
    375
    Ventura County, CA
    Take a close look at the cables coming from the battery to the starter. They could be corroded under the insulation and appear OK from the outside. I've had this occur on my truck before.
    Dan..
  5. 3 on the tree
    3 on the tree 1/2 ton status
    Oct 16, 2004
    3,970
    gunnison colorado
    Dang, Duane, you still can't get the fuse lit on the Cherry Bomb???
    Try bypassing ALL the truck wiring.
    Run jumper cables from battery to starter, both pos and neg
    Use a remote starter button set up
    If it spins properly with the wiring bypassed:
    Unhook the ground jumper cable and try to start.
    If it spins slowly, then you have a bad ground.
    If it spins properly, then re-attach ground cable and unhook hot cable.
    If it now spins slowly, then you have a bad hot connection, or bad cable.
    I have run into slow rollers on a fresh rebuild, but that was high comp motors. I once had to run 24V to a HOT 383 to get it turn fast enough to fire up.
    I hope it is something as simple as a battery.
  6. Confedneck79K30
    Confedneck79K30 3/4 ton status
    Oct 1, 2006
    5,384
    LA
    why not get a hi-torque starter...
  7. resurrected_jimmy
    May 23, 2005
    2,241
    back home in Houston
    If your valve train is too tight like that on a brand new motor, they will behave like that
  8. NoReGrEtS
    NoReGrEtS 1/2 ton status
    Nov 7, 2005
    848
    Moreno Valley,SO CAL
    and if it isnt lubed
  9. Confedneck79K30
    Oct 1, 2006
    5,384
    LA
    yeah, depending on your compression, you may want to hook a battery charger on HI setting and see how that helps...
  10. 70jimmy
    Mar 3, 2000
    5,953
    248
    opfor2: Brand new cables and wire to starter.
    3 on the tree: Sounds like good stuff to try. Just hoping it isn't an issue with the new motor!!!
    Confedneck: Yep high torque starter is in the works. I have heard of people putting a starter for a newer chevy on that supposedly has more torque????? I know wummit and jegs have hi torques. Now just to find more money!!
    resurrected_jimmy and no regrets: Valve train well lubed and proper cam lube used on install. Engine pre lubed a couple times also.
    Confedneck: Yep charged the battery for several hours and no difference.
    After dinner I am gonna go check the amps when cranking and if that is low I might swap another battery out of my (gulp) Exploder and see if that helps.
    Thanks for all the replies. I sure hope I don't have to jerk this motor out and re do it again!!!!!!!!!!!!!
  11. Confedneck79K30
    Oct 1, 2006
    5,384
    LA
    listen, easiest way to do this, hook up that battery charger on hi, and try and start it, with it charging, see if that helps... but your starter might just not have the ass it needs...
    our local parts stores sell high torque starters, usually a machine shop will too...
  12. 70jimmy
    Mar 3, 2000
    5,953
    248
    Update: Checked cranking amps and it is just over 300 and doesn't vary.
    I let the battery charger charge for a while and then tried it with charger hooked up and on 6 amp setting (highest) No change
    I hooked jumper cables from the explorer to the jimmy battery and no change.:mad:
    Off to try more stuff.
  13. MaxPF
    MaxPF 1/2 ton status
    Apr 13, 2006
    2,207
    Chandler, Arizona
    I agree with making sure the heavy cable between the battery and starter is in good shape. And heavy enough - the regular smallblock starter draws quite a bit of juice. Which brings be to the second point: Regular (i.e. non-gear reduction) starters suck. They sucked in 1955 and they still suck. They suffer from heat soak as well as every other ailment imaginable. I found out that the starters used on late model (i.e. 97 up) 4.3 V6's are gear reduction and can easily turn over a smallblock (it's only 33% more of an engine, after all). S10 warehouse has em cheap - I paid $30 for mine :deal:. I put it on my daily-driven K5 in June after my "regular" starter left me stranded a couple of times. I haven't had a bit of trouble since. I've seen these starters go 200k miles, so a low mileage used onbe should last a good long time :thumb:
  14. 70jimmy
    Mar 3, 2000
    5,953
    248
    Thanks Max good info, and within the budget!!!!!:wink1:
  15. 3 on the tree
    Oct 16, 2004
    3,970
    gunnison colorado
    Good rule of thumb: Minimum 1 cranking amp per cubic inch. If your battery has a bad cell, it could be draining the Ford battery. I would try a known good battery, instead of the one in the Bomb.
  16. MaxPF
    Apr 13, 2006
    2,207
    Chandler, Arizona
    Oh, I forgot to mention that the bolts holding your current starter on will be too long for the V6 starter. Just go down to your local friendly hardware store with the new starter in hand and score yourself some proper length bolts :D.
  17. NoReGrEtS
    Nov 7, 2005
    848
    Is it wired the same?
  18. MaxPF
    Apr 13, 2006
    2,207
    Chandler, Arizona
    Yup. There may be an extra terminal on the back (I cant remember). If so, simply leave it disconnected.
  19. NoReGrEtS
    Nov 7, 2005
    848
    sweet I needed a new starter, 97 S10 4.3 got it.
  20. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    Something nobody has brought up yet........
    You stated that you haven't even run this particular motor yet. Is there a possibilty that you have the sucker timed WAY too advanced? That can cause hard starts.
    Just a thought, brother.
