Slow electric windows
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by lehtola, Apr 12, 2001.
  1. lehtola
    lehtola 1/2 ton status
    Mar 21, 2001
    192
    North Carolina
    I want to lube my tracks. What are the steps to getting to the tracks on the door windows? Anyone done this lately...and is it o.k. to use lith grease or do I need to use something else?
    1990 GMC Jimmy 350/TH700R4/NP241/10 bolts, 4" skyjacker lift, 35x12.50R15 BFG All Terrains on 15x10 AR Baja's, Flowmasters.
  2. dyeager535
    26,980
    I'd probably use lithium grease or something like lubriplate.(water resistant, kind of thin, shouldn't gum up) All you really have to do is take the door panel off and roll the window up and down...the track that you grease is right underneath the window, and moves. There are rollers that ride in the track, these sometimes wear out or break also.
    Dorian
  3. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    also spray the felt window guids with white (teflon) oops not teflon i meant GRAPHITE spray NOT TEFLON spray SORRY. you can get black or gray but white works best and that helps a lot
    77blazer see it at<A target="_blank" HREF=http://community.webshots.com/user/ssmith6333>http://community.webshots.com/user/ssmith6333</A>[​IMG]<P ID="edit"><FONT SIZE=-1>Edited by mudhog on 04/12/01 03:00 PM (server time).</FONT></P>
  4. ChevyCaGal
    ChevyCaGal 3/4 ton status
    Dec 16, 2000
    8,158
    Sacramento, CA USA
    Clean the track out when you take off the door panel. Mine on my passenger side would stick and I'd have to yank it up by hand. I took off the panel and the crud in the track was nasty! I cleaned it out and greased it and it works soooo much better now. [​IMG]
    Stephanie
    &lt;&gt;&lt;
    "Suck Fumes Ford Boy"
    "I love my country, I fear my government"
    "What if the hokey pokey is what it's all about?"
  5. Espen88k5
    Espen88k5 1/2 ton status
    Feb 19, 2000
    981
    Norway
    The window slides in filt channels on each side of the door. The can slipp out of position and bundle upp towards the bottom. These doors are windy and leaky. rainwater runs right on the regulator and sahs-channels. Road dust and grime gets in there and makes a sirupy mess of everything. I sugest a disassembly, de-greasing and regreasing.
    <A target="_blank" HREF=http://www.espen88k5.coloradok5.com>http://www.espen88k5.coloradok5.com</A>
  6. lehtola
    Mar 21, 2001
    192
    North Carolina
    Thanks everyone. I haven't gotten to it yet but saturday morning looks like a goody to me. I'll let you know what happens.
  7. lehtola
    Mar 21, 2001
    192
    North Carolina
    Well...I lubed them up real good but it didn't seem to make a noticable difference. They work but I thought they'd be faster.
  8. cederic
    cederic Registered Member
    Apr 4, 2001
    31
    Nebraska
    Just went thru the same thing with my 85. I took it apart, cleaned it, re-lubed it with white lithium grease and reassembled.
    Better, but not quite right.
    So I spent $42 per door and replaced the motors. I guess all
    of the work those motors put out trying to push thru the old grease and dirt just wore them out. Mine had some definate signs of overheating because the wire coupling was melted a little bit.
    Spend the money the first time you take it apart I guess.
    The drivers side took me about an hour to do. The passenger side only took me about 40 min. Of course I did all the cleaning on the passenger side the first time I took it apart.
    What do you call a fly after you pull off it's wings ?
    A WALK...ahhehe
  9. kpanza
    kpanza 1/2 ton status
    Dec 8, 2000
    1,579
    Lake Forest, Orange County, California
    I went ahead and cleaned mine out this weekend, what a difference!! I used some silicone grease on the rollers and lubed everything. Man, I never thought I would get those windows to work! Thanks for the post guys! I called my brother out so that he could witness it, he couldn't believe that he wouldn't have to actually pull his window up anymore by hand!! ha,ha
    Thanks again!
  10. KrebsATM02
    KrebsATM02 1/2 ton status
    Mar 21, 2000
    553
    College Station, Texas
    My windows almost made me cry this weekend. If ya'll read my previous posts you know that the wires were breaking off of the little clips that go on the terminals. We'll i looked every where for the clips and couldn't find them, so i decided to just solder the wires on there and use bullet connectors for the disconnect. So it worked good except that i must have melted something in the passenger side of the switch because it doesn't work at all now. I am so frustrated. So i know i can get a new switch at the dealer, but i need the harness with all the little clips in it. Any one know where i can get these cheap??? Or at all??? Thanks - Doug
    Doug Krebs
