Slow Pig
Discussion in 'The Garage' started by demoore17, Dec 9, 2003.
  1. demoore17
    demoore17 Registered Member
    Dec 9, 2003
    6
    HELP, I just purchased a 1985 K5 with a Jasper motor with the performance package but the DPO replaced the original/stock 4 barrel with a two barrel rotchester.....I had just installed a Holley Street Dominator Manifold (idle to 5500 rpm) and a Holley 650 Carb....know she is slow as a pig, I am going to have the T.V. cable adjusted tomorrow to get the Tranny back in line but I dont think it will do the trick. I am still running the stock Dizzy (HEI)and have about 8 degrees of advance.....
    WHAT DID I SCREW UP?
    Any thoughts suggestions or opinions are most welcome
    Thanks /forums/images/graemlins/1zhelp.gif
  2. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    Does she stumble? Are there any things you can tell to hint maybe? Was teh carb brand new? Done any carb tuning?
  3. Topdown
    Topdown 1/2 ton status
    Nov 26, 2002
    2,598
    Vancouver, Washington, U.S.A
    what is the operating rpm (power band if you will) of the engine? are you under revving or over revving it? I know that some engines dont have much until you hit like 3500rpm then they go nuts.
    Also, carb tuning and distributor tuning will definitely need to happen.
  4. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    Gearing is a big issue as well. My K5 was a dog but the motor ran fine it was the fact that I ran on 2.73s and 33s.
  5. Topdown
    Nov 26, 2002
    2,598
    exactly... thats what I mean/meant by under or over revving it. If your running a 3.08 with a 39.5" tire your gonna have a dog... at the same time, if your running a 7.13 with a 30" tire your going to blow sky high and run the engine out the backside of its operating range. Though this is fairly uncommon...
    /forums/images/graemlins/thumb.gif
