SLOW windows
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Hayduke, May 14, 2000.
  1. Hayduke
    Hayduke 1/2 ton status
    May 9, 2000
    271
    NE Columbus, Ohio
    the power windows on my Jimmy didn't move at all when i bought it but after some oil on the tracks they started to creep. but that's as much as i can get out of them, VERY slow. i've priced moters and they aren't too bad, should i go for just new moters or replace all the wiring and switches too?
    thanks
  2. My old 77 K-5 had slow to no-go windows and I took everthing apart and cleaned, lubed, and 3-1 oiled the motor and whallaaa they worked like they were brand new. Check out all of the guides for wear. Sometimes this will cause the glass not to line up and cause it to slow or stop. Good luck. I would go with a new motor if the above doesn't work or help. The wiring would probably be allright !!
    [​IMG]<font color=red>BigBurb[​IMG]
    <font color=purple>IF YOU'RE SCARED, SAY YOU'RE SCARED !!
