slow windows?
Discussion in 'The Garage' started by 88GLAZER, Apr 24, 2003.
  1. 88GLAZER
    88GLAZER 1/2 ton status
    Nov 19, 2002
    111
    West Virginia
    I installed new window channels and now I can barely get the windows to move. They were slow to begin with. do I need new motors?
  2. scrappy88
    scrappy88 1/2 ton status
    Mar 14, 2003
    314
    Loveland, CO
    Make sure the channel is properly seated in the division bar between the window and the small vent window. I had the same problem on my 88 after replacing the window channels, and found that I didn't have it seated properly in the division bar. You have to press really hard on it and it will sort of click in place. Make sure the entire length is seated too, even inside the door. It fixed my problem. /forums/images/graemlins/thumb.gif
  3. ds350
    ds350 1/2 ton status
    Jan 26, 2001
    190
    Bay Area
    Additionally: Clean and put some fresh grease on the window channels. They are know to sieze up and bind without some fresh lube!
  4. fulltopblazer
    fulltopblazer 1/2 ton status
    Aug 1, 2001
    484
    Altus,Oklahoma 73521
    yeah clean everything out real good and re grease it all.
  5. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    Also check to make sure that the motor is getting a full 12 volts and, like the others said, grease the regulators and the channels up real nice-like! /forums/images/graemlins/grin.gif
  6. Krase
    Krase Registered Member
    May 19, 2002
    90
    Northeast ,Tennessee
    This may be too simple but mine are slow, because the pin connectors on the switches keep loosening, i had to put nuts on the back of them to keep them from moving when i did my windows work just fine. But they would get incredibly slow. Just an easy option to check.
