sluggish when cold help
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by DMK, Oct 16, 2001.
  1. DMK
    DMK 1/2 ton status
    Feb 20, 2000
    757
    CINCINNATI, OH
    Truck is very sluggish when cold once warmed up runs great. Have already changed coolent temp sender, map sensor. What should I check next. Truck is an 87 350 auto
    all emissions are hooked up. Also just changed wires, plugs,cap rotor and ignition moduale. Plugs did look lean.
    Thanks Doug
  2. Maybe it's just a cold blooded SOB like mine. If you do find a fix, let me know.
    God has a hard on for Marines, because we keep Heaven chock full of fresh souls!
  3. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
    Do you have the stock air cleaner still on? If so, there should be a preheater hose attached to it that goes to the exhaust manifold. On the air cleaner side, there's a door that should be open letting warm air from the exhaust in when it's cold preventing sluggish running. It's a smog item also. Me, I run an open air cleaner so it runs sluggish when cold.
    Bubba Ray Boudreaux,
    "It wastes drinking time."<a target="_blank" href=http://community.webshots.com/user/mdntrdr1>http://community.webshots.com/user/mdntrdr1</a>
  4. Can Can
    15,555
    156
    Cochrane, Alberta, Canada
    I agree with Bubba.........Make sure that the vacuum-actuated door on your air cleaner housing is closed(sucking in hot exhaust air) when the engine is closed.
    Another thing to check is to make sure that your heat riser(on the exhaust pipe right below the passenger-side manifold) is closing when you start the truck. It's vacuum=actuated as well.
    If either of these pieces isn't working properly, the cold air that the engine sucks in at startup can actually coat the carb with a thin cover of ice, causing bad throttle response and poor idle. The more moisture in the air, the worse it will run....
    <font color=blue> NEVER FORGET, NEVER FORGIVE, NEVER SURRENDER<font color=blue>
  5. Bubba Ray Boudreaux
    Jan 21, 2001
    20,716
    Don't know about all of them, but on mine, the door is controlled by a thermatic spring.
  6. DMK
    DMK 1/2 ton status
    Feb 20, 2000
    757
    CINCINNATI, OH
    Everything connected, there is no heat riser on tbi. Anything
    else. Thanks for previous replys.
  7. CV202
    CV202 1/2 ton status
    Nov 14, 2000
    454
    Kingfield, ME
    Interesting, the TBI on my 1990 has a heat riser coming off the passenger side manifold to the air cleaner housing.
    Why do people keep calling it a Bronco!!!!! [​IMG]
