SM 420 2wd and 4wd version?
Discussion in 'The Garage' started by tellmehow, Jul 11, 2004.
  1. tellmehow
    tellmehow Newbie
    Jul 11, 2004
    Los Angeles, Ca
    Hey guys! Anyone know if the SM420 off a 1966 2 wheel drive 3/4 ton truck will work for my 4x4 blazer? Some guy wants $100 for the trans with bellhousing & I'm not sure if this trans is what I need /forums/images/graemlins/confused.gif Thanks
    Frank
  2. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    go price the required adapters
  3. tellmehow
    tellmehow Newbie
    Jul 11, 2004
    Los Angeles, Ca
    do you know what company makes the adaptors?
  4. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    Advance Adapters
    Novak
    the bottom line is that it isnt worth it when a $50 sm465 bolts up
  5. GMCLegacy
    GMCLegacy 1/2 ton status
    Jan 24, 2002
    620
    Grand Haven, MI
    also the ball stud that the H Bar for the clutch linkage was placed on the engine blocks back then, where as a 465's is on the bellhousing.
    id like to have a SM420 for its shift pattern, but the no sych 1 and 2 is a downfall.
  6. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    Ballstud location is year specific. Split is 72/73.
    SM420 is syncro 2nd... except when it's worn out. /forums/images/graemlins/grin.gif
    EDIT: Only married t-case adapter is for the SM420 is a Rockwell T221. ('67 only)
  7. GMCLegacy
    Jan 24, 2002
    620
    Grand Haven, MI
    hmmm, learn something new everyday.
    so there are 465 bellhousings without a ball stud for the h-bar? is that an aluminum or cast iron bellhousing for those goofed up years?
  8. u2slow
    May 9, 2001
    2,217
    BC Canada
    68-72 use block-mount ballstud and cast bellhousing with correct index for SM465.
