SM 465 clunking
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by mountainexplorer, May 10, 2002.
  1. mountainexplorer
    mountainexplorer 1/2 ton status
    Nov 14, 2001
    4,903
    Spokane, Wa./Ione, Wa
    At idle and not moving, the SM465 4-spd in my Suburban makes a clunking (almost a knocking) noise. It is less noticeable when the clutch is engaged and not noticeable at all when driving. What could it be?
    I already pulled a motor out because of the noise (thinking it was knocking), and now I found out it's in the tranny somewhere.(doing the exact same noise with a new motor).
  2. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    when you pulled out the motor did you put a new clutch in?
  3. wrathORC
    wrathORC 1/2 ton status
    Apr 27, 2002
    908
    Hancock, MI
    Yank the trans and look at the input shaft bearing and race. You'll probably find that there is a lot of chrome missing off both. While I was in there I'd replace the seals at both ends and check the output shaft bearing and race. I might even convince myself in to buying a couple new synchronizers.
  4. TXsizeK5
    TXsizeK5 1/2 ton status
    Aug 26, 2001
    2,518
    College Station, TX
    This happened to me also...
    after romping one time i was sitting in a parking lot and had it in neutral and let off the clutch pedal and there was a *knock knock knock knock* type noise and i was like wtf... but the next day I checked it out and it was cool... somone told me it could be the flywheel. I have no idea =X
  5. mountainexplorer
    Nov 14, 2001
    4,903
    The clutch was a used one that I had recently put in my other truck. It was still in good shape.
    Once in a while the shifter jams in 3rd, and sometimes on a quick shift, it grinds between 3rd and 4th. It also sat half uncovered for about 6 months. When I put it in the Suburban, I drained out quite a bit of water and added new 90W gear lube.
    It also sounds like my tranny-Tcase coupler sleeve has some play in the splines. I just don't want to pull the thing out, since I just put the whole thing together, but maybe I'll have to.
