SM 465 fit
Discussion in 'The Garage' started by odoa3, Mar 9, 2005.
  1. odoa3
    odoa3 1/2 ton status
    Mar 31, 2004
    1,638
    Anchorage, AK
    I know nothing about transmissions, but trying to learn. I have a TB 350 in a 75 K5 that needs to be rebuilt. I just ran across a four speed with granny 1st gear out of a 85 K5 that had an electrical fire yesterday. First question- this is a SM465, correct? Second, will this swap be a direct bolt in? Found the how to write up in the technical section so I will be following that closely. Just a little worried about the different tail shafts, and any other issues that might pop up I don't know about. Thanks for the help.
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    yes its the sm465/np208. this swap is not a bolt in swap for the older trucks. you will need driveshafts, and redrill the frame for the crossmember. there are a few small things that were changed from year to year, but i have solved them (doing to swap as we speak, almost done also)
    im working on a more complete write up for this swap also, mine is a 700r4-sm465 swap though.
  3. spoolnaround
    spoolnaround 1/2 ton status
    Apr 8, 2002
    1,419
    Kingsburg Ca
  4. odoa3
    Mar 31, 2004
    1,638
    Anchorage, AK
    Spooln- thanks, I downloaded that earlier and have been going over it.
    I will have to find a new crossmember for this, correct?
  5. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    you will need a new crossmember because the 85 uses the short adapter.
  6. AkMudr
    AkMudr 1/2 ton status
    Dec 30, 2004
    917
    Alaska
    Hey odoa lets keep things simple....when I get to anchorage you canhave my th350 and I'll take the 4speed, but only if you have all the linkage, pedals and if its bydro :D :D
  7. odoa3
    Mar 31, 2004
    1,638
    Anchorage, AK
    Hey, I may take you up on that! If I can get the guy to give me a call back! Swing by a federal reserve on your way up and grab me some money so I can get everything done this summer, OK?:D
  8. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    It's not too bad.
    Make sure you get everything. That means pedals, reservoir, master cylinder, hose, slave cylinder, clutch fork, bellhousing, flywheel, clutch, and transmission. It'd also be a benefit to get the crossmember.
    The hose and clutch fork alone are $100 from the dealership. The slave cylinder is like $60 from the auto parts store. The flywheel is $75. A "decent" clutch will cost you $140. Get all the bolts also because flywheel and flex plate bolts are different lengths. You'll need the bolts that go between the trans and bellhousing because they're metric.
    I have $600 into the parts for SM465/NP208 swap and I'm not even done yet. That doesn't include $70 for the clocking ring or the fact that I never opened up the 465 or 208 to see if anything needed maintenance/repair/replacement.
  9. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    mine were standard and bellhousing was from an 89 C&C 1 ton.
    i have $290 into everything for my swap (im done BTW), so it does range.
    here is my write up, i even have the measurements for the hydro master cylinder on the firewall.
    http://www.midwestoffroad.com/big83chevy4x4/auto-manual-swap-chevy.htm
  10. odoa3
    Mar 31, 2004
    1,638
    Anchorage, AK
    Thanks Cyber and Big83, exact type of information I was looking for. :waytogo:
