SM 465 gear lube
Discussion in 'The Garage' started by eshorvath, Sep 15, 2005.
  1. eshorvath
    eshorvath 1/2 ton status
    Jun 20, 2002
    373
    Southern Oregon
    Should gear lube be present in the adapter between the manual 465 and the transfer case?
  2. Robert79K5
    Robert79K5 1/2 ton status
    Mar 23, 2003
    335
    Douglasville Georgia
    Yeah. Depending on the adapter there should be either one or two seals in the adapter to keep the fluids in their respective components. Other than that your transmission is free to sling fluid all around in there.
    I run a np205 so I could care less if theres gear lube in my adapter since my transmission and transfer case use the same stuff. If you run a transfer case that uses ATF you may want to periodically check the fluid to ensure that the two different lubes arent mingeling with one another.
  3. eshorvath
    Jun 20, 2002
    373
    Southern Oregon
    There isnt gear lube going into my TC, so I know the TC frong seal is still good.
    I only wish I knew where the small leak from the front of the tranny is coming from, the front seal of a gasket somewhere, i guess id have to pull it to find out...ouch.
    Eddie
