sm 465 output shaft?
Discussion in 'OffRoad Design' started by Thumper, Oct 25, 2004.
  1. Thumper
    Thumper 1/2 ton status
    1,582
    Alberta Canada
    I cant find a listing or price for your 32 spline output conversion shaft for a 465 thats mentioned in the desc of the doubler. I have a 10 spline 465/205 combo now.
    I am going to round up some parts, and the two choices I have are:
    1. to find a 465/203 10 spline unit then buy the 205 input conversion shaft to make it 32 spline. Your kit replaces the output shaft of the 203 right? Total is 770+200+ cost of the 10 spline 203.
    2. find a 32 spline 203, buy the 465 output conversion shaft (10spl to 32) then total is ?+770+200.
    Not sure which direction I can go yet until I find (or fail to find) the right parts. With our CDN dollar climbing, the price is USD is getting better!
    So, if you can quote me a price of that shaft, Id appreciate it.
    Mike
  2. dhdescender
    dhdescender 1/2 ton status
    Aug 10, 2002
    628
    Qualicum Beach, British Columbia, Canada - Eh.
    I have the stock SM465/NP203 adaptor that the shaft works in conucntion with, the hortest means possible for the 465. PM me if your interested.
  3. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    How much for the adaptor? Would be shipped to 77084 Houston, Tx
  4. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    I think this last batch ran $340 each for the 465 32 spline short output. We can source the input gear for the 203 for you or you can find a 203 with the 32 spl. input yourself. Either way works. Last batch of 203 input gears is going for $155.
  5. Thumper
    1,582
    Alberta Canada
    Where would a donor 32 spline 203 come from? Is there specific years to look for and specific trans combos to look for? Will all 32 spline combos work or are the 465 units different?
    Thanks for the info.
    Mike
  6. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    The only 32 spline 203's I know of are TH400/203 setups. They are hard to find and usually expensive.
    Is length an issue with your doubler? If not you can get a 32 spline 465 from a truck that has a 465/208 or 465/241 setup. They are long output though and you need that adapter. Then you need the 32 spline 203 still.
    Harley
  7. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    32 spline 203 comes in the factory 400/203 combo. Or you can use any GM 203 and swap in a 32 spline input that we generally have on the shelf. They run $155 at this point.
    You can use the factory 465/208 adapter, it's just 4" longer. For some it's the best way.
