SM 465 shifter
Discussion in 'The Garage' started by velocitiii, Dec 30, 2003.
  1. velocitiii
    velocitiii Registered Member
    Dec 19, 2003
    54
    I'm looking for a GM 1 ton 4x4 and a couple I've looked at had the 4 spd. They all have so much play in the shifter that its tough to tell if they're in neutral or in gear without letting out the clutch. Is this normal? If not, what is required to fix it?
  2. tRustyK5
    Jul 23, 2000
    36,169
    1,368
    E-town baby!
    Compared to a car manual tranny they are sloppy feeling. The length of the shifter exaggerates the effect. In gear my shifter can be moved 2-3" side to side.
    Rene
  3. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    It's normal and after a while you'll get used to it and will know exactly where neutral is. It's really not that hard to find since all of the actual gear positions are at least a foot or so away. /forums/images/graemlins/eek.gif /forums/images/graemlins/wink.gif /forums/images/graemlins/cool.gif
    BTW, granny low and reverse are not synchronized in those trannies. To prevent gear grinding when shifting into either of those gears, push in the clutch and shift to 2nd gear and then shift into granny low or reverse. Otherwise you'll get strange looks from bystanders as they wonder why your tranny is grinding so loudly. /forums/images/graemlins/shocked.gif
  4. bryguy00b
    bryguy00b 3/4 ton status
    Apr 7, 2002
    5,587
    Rochester, N.Y
    ohh i soo wish i had a standerd /forums/images/graemlins/frown.gif
  5. dyeager535
    26,977
    Some play (much compared to a car tranny) is normal, but there are some problems with the shifters that apparently can be fixed. The bottom of the shifter has a weld that breaks, increasing the amount of slop.
    I believe some have stated that their shifters touch the dash when in the "forward" gears. (L and 2 IIRC) I have an '85 tranny I pulled from a truck, and one thats in my truck which is a '74. The '74 has noticeably more slop, and I know the weld is broken on it. The '85 isn't.
  6. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    shifter play on top loader 4 speed is good, is way tons more than tiny car manual trannies
    i hav a hard time with car side loader tranies, but a 465 or 420 or 435 i can shift damned easily, i cant stand car manual side loader trannies
    they suck,
    good luck
  7. landsmasher
    landsmasher 1/2 ton status
    Mar 13, 2002
    4,423
    California, The Blow Me State
    Mine does... Doesn't have to but ususally it does.
