sm 465
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by OldBlew, Mar 11, 2002.
  1. OldBlew
    OldBlew Registered Member
    Mar 10, 2002
    28
    Girdwood, Alaska
    Can anyone tell me about the sm465? It appears that it was the only 4 speed available from the early '70's up until '91. I am looking at buying a k20 pickup that was made in Canada. Did the Canadian models vary?
    If they did, were the 4 speeds they used any good??
  2. K10ANDYKHAMNIC
    K10ANDYKHAMNIC 1/2 ton status
    Sep 17, 2001
    1,962
    Western CO
    im not sure when they used it but there was another 4 speed the sm420 but i think it was used in older models
  3. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    my truck has a sm465
    and
    I am Canadian
  4. solowookie
    solowookie 1/2 ton status
    Mar 31, 2001
    3,880
    Wyoming
    yea it was used in older models; basically shift pattern is the same, but reverse if over and down towards the driver instead of away. bolt pattern is different too (just pulled one outta my 1950 chevy truck that I'm tossing, but I think they stopped using them in 67 - or there about)
  5. RedDwarf
    RedDwarf 1/2 ton status
    May 9, 2001
    816
    North Central Florida
    465 came in in 68 and ran to 91
    "but reverse if over and down towards the driver instead of away. "
    I did not realize that. You learn something every day /forums/images/icons/smile.gif
  6. solowookie
    Mar 31, 2001
    3,880
    Wyoming
    yea it is, and its kinda annoying... we've had a tranny like that for years in our cattle truck, but I didn't really it was a sm420... /forums/images/icons/tongue.gif LOL
  7. arq
    arq 1/2 ton status
    Jan 17, 2001
    2,017
    Imperial Valley/Maricopa
    465 output shaft came in 2 versions 10 spline and a 32spline. not sure but someone correct me the 32spline came out in 81.
    ARQ.
  8. dyeager535
    26,982
    191
    Not the only four speed available, there was a "car" transmission available for a few years as well, it has external linkage though, and would be easily identified if you crawl under the truck.
    There is an arly 80's truck in the yard here with a 208 in it, with factory non-SM465. I think GM got wise and dumped that idea after only a couuple of years though, thats the only non SM465 I've ever seen in a truck our vintage.
