sm 465
Discussion in 'The Garage' started by edlavarreda, Mar 16, 2004.
  1. edlavarreda
    edlavarreda Registered Member
    Nov 26, 2002
    56
    how do you take the stick shift off? thanks gurus
  2. GMCLegacy
    GMCLegacy 1/2 ton status
    Jan 24, 2002
    620
    Grand Haven, MI
    first make sure the tranny is in neutral. remove the rubber boot. you will see a metal ring around the shifter socket on the top loader. push the ring down and twist counter clockwise, the shifter should be free. some you can get with bare hands, others you may need to grab with a large pair of channel locks. if you take it out and the tranny is in gear, you will have a hard time putting it back in, you will need to re-align the shift forks with a screwdriver of some sort, and start again.
  3. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    to take just the shifter out, the round cover at the base of the shifter, push down and turn counter clockwise. and then you can remove it. make sure it is in neutral first.
  4. edlavarreda
    Nov 26, 2002
    56
    thanks alot gurus
  5. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    sometimes have to use big pliers to make the spring loaded cover turn, some are tight/stuck,
    SM420 handle removes same way BTW
    good luck
