SM465-203/205 SETUP?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by mudddog91, Dec 23, 2001.
  1. mudddog91
    mudddog91 1/2 ton status
    Dec 28, 2000
    471
    north carolina
    Anyone running this combo yet,I mean the doubler attached to a 4 speed manual tranny?How did you do it?Im thinking of doing this setup and was wondering about the overall strength if I were to use the 10 spline deal.Wouldnt the strength the be the same as it is now?
  2. RaisedK5
    RaisedK5 1/2 ton status
    932
    Long Beach, CA
    Ok now im not running it but its sitting in my yard, and i wish you'd asked this before i took the silly thing apart, but thats not your fault, anyway the 465 version 203/doubler/205 is @26 inches from the face of the tranny adapter to the centerline of the rear yoke, (thats if my math is right) i took it apart an hour ago so i could get it out of my truck by myself. I'm actually putting it behind an auto, but hopefully that answered at least one of your questions, give me a month and i'll tell you how i like it. Oh and one of the biggest benifits, beside the gearing, to having the doubler is, especially with the 465, a longer front driveshaft.
    Leland aka RaisedK5
    "Of all the things I've lost, I think I miss my mind the most!"
    "Are the voices in my head bothering you?
  3. titanic
    titanic 1/2 ton status
    Mar 27, 2000
    498
    north alabama(huntsville)
    It's plenty strong. I've used this setup for the past two years and others on this board have seen me at Tellico with 8000lbs riding on it. Be sure to make two crossmembers to support both transfers and after you drive for a couple of weeks ,re-torque all the 9/16 bolts that hold the two transfers together. Steve
  4. Butch
    Butch 1/2 ton status
    Apr 26, 2000
    1,338
    Austin, TX
    Ran mine last season and love it. It is plenty strong and like Titanic said just make sure you use double crossmembers. The overall length is the same as having just a NP203. My front shaft used to bind prior to the doubler, but now it has length that I can flex out the truck. You also negate the need for a clutch. When you come up to an obstacle you can just hold the brakes and almost stop the truck from rolling without killing the motor. Auto's are for girls :-))))
    I thought I was wrong once,
    but I was mistaken
  5. 1bigk10
    1bigk10 1/2 ton status
    Dec 20, 2001
    151
    Medford Oregon
    raisedk5 ht does the input shaft on your 203 rangebox look like? is it 10 splined and is it male or female?
    1982 K10 Silverado. [​IMG] 327 SHPE powerplant SM465/205,15"custom lift 38.5"TSL/SWAMPERS 12boltrearD44 front,3.73 gears.
  6. michaelm
    michaelm 1/2 ton status
    Feb 2, 2001
    872
    <a target="_blank" href=http://wsphotofews.excite.com/027/H2/1G/P6/9475781.jpg>http://wsphotofews.excite.com/027/H2/1G/P6/9475781.jpg</a>
  7. RaisedK5
    932
    Long Beach, CA
    Its a ten spline female, hooks right up to the back of the 465, now before you ask, no im not going to use it but someone has already spoken for it. But ya all you need is the 465 to 203 adapter, (@ $150 according to Stephen Watson), and a 465 input for the 203 (also $150 per SW). then you can drop it into any 203 range case, and hook the doubler to the back of it. easy! All it takes is money!
    Leland aka RaisedK5
  8. 1bigk10
    Dec 20, 2001
    151
    Medford Oregon
    thanx for the info my buddy has one that i am getting for$100 transfer and adapter. but neede a pic to see what i was looking for you guys are great
  9. mudddog91
    Dec 28, 2000
    471
    north carolina
    Thanks for all the info.I will be looking for this elusive 465 version of the 203 a soon as possible.Are they really that difficult to come by?If so it may be worth it to buy the stuff from ord and just go on with it!Thanks again everyone.
