sm465/205or208combo
Discussion in 'Parts & Trucks Wanted' started by lifethroughdeath, Mar 22, 2004.
  1. lifethroughdeath
    lifethroughdeath 1/2 ton status
    Jan 26, 2003
    300
    New Bedford, MA
    title says it all, im looking for an sm465/205or208 combo, with any and all accesories(swapping from 700r4). I'm in MA, but anywhere on the east coast would probably be fine. Thanks, Nate /forums/images/graemlins/k5.gif
  2. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Re: sm465/208 combo
    Just an FYI if you don't already have the 208 for the 465 you will need it, or at least its input shaft. it is different then the input shaft on a 700R4 version 208.
    If you can get the input shaft itself you can swap it into your current 208 from the 700R4. Otherwise you will need the whole 208 from the 465 because a 700R4 version 208 will not swap onto a 465 trans. The spline count on the input shafts are different.
    Harley
  3. lifethroughdeath
    Jan 26, 2003
    300
    New Bedford, MA
    Re: sm465/208 combo
    hey thanks for the info, i changed my post to what it should have said from the begining
  4. jackedjimmy350
    jackedjimmy350 1/2 ton status
    Oct 20, 2000
    3,141
    Fort Smith, Arkansas 72901
    Re: sm465/208 combo
    got one, prolly cost quite a few pennies to ship thou /forums/images/graemlins/crazy.gifgh.
  5. 75-K5
    75-K5 3/4 ton status
    Apr 28, 2002
    5,353
    Anderson, Indiana
  6. lifethroughdeath
    Jan 26, 2003
    300
    New Bedford, MA
    Re: sm465/208 combo
    [/ QUOTE ] what exactly do you have? i'll check on shipping
  7. jackedjimmy350
    Oct 20, 2000
    3,141
    Re: sm465/208 combo
    just your run of the mill 465/205 combo. its in great looking shape, just pulled it from a non running '86 one ton crew cab 2 weeks ago (almost positive it isnt the original setup). i was amazed at how clean it was...like hardly any dirt or grease build up compared to what you usually get from a parts rig. the tranny and t-case both shift thru all gears smoothly.
    it will come with both chrome shifters, shifter boots, and crossmember. i guess you can hav ethe driveshafts too if ya want. i dont need them /forums/images/graemlins/thumb.gif
    fyi...ill put it on a crate shrink wrapped and take it to the fedex freight terminal for free. my dad has a business account there, so he gets a considerable discount. i bet it'll still be expensive though since it weighs so much. /forums/images/graemlins/crazy.gif /forums/images/graemlins/thumb.gif
  8. lifethroughdeath
    Jan 26, 2003
    300
    New Bedford, MA
    Re: sm465/208 combo
    i'll have to call the freight place tommorow (freightcenter.com)to get an exact quote, the rough one they sent was $130, which aint too too bad. but i'll have to get back to you. PM sent. Thanks
