SM465 2nd and 3rd gear ratios- what are they?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by ponderingjunkman, Jan 20, 2002.
  1. ponderingjunkman
    ponderingjunkman Registered Member
    Dec 6, 2001
    14
    Cairo, NY
    Anyone know what 2nd and 3rd gear ratios are for the 465? I know that 1st is 6.55 or 6.58, also 4th is 1 to 1. I want to use the online calculator to figure out my speeds till I can afford Autometer's fancy speedo that compensates for tires/gears electronically. Anyone run this speedo? There was a mag write-up a couple years ago on it. Since I am combining a pile of parts that probably won't like each other, I figure this speedo will be the slick way out of the inaccurate speedo dilemma. So if I knew those ratios, I can get by cheap for now!! Thanks!!
    No Replacement for Displacement
  2. TXsizeK5
    TXsizeK5 1/2 ton status
    Aug 26, 2001
    2,518
    College Station, TX
    Low- 6.54
    1- 3.57
    2-1.57
    3-1.00
    Reverse is something around 4 I THINK
    Hope this helps man.
    87 Custom Deluxe
    305/Sm465/ NP208
    4.56 , 35" BFG Muds, Series 40 delta flow 3" tips
    Coming Soon: Suspension Work, Eaton Posi, More Exhuast work.
  3. JIMs70K25
    JIMs70K25 1/2 ton status
    Dec 31, 2001
    524
    Chesapeake, VA
  4. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    <a target="_blank" href=http://www.4lo.com>Heres the chart</a> to all the tranny's and thier rations, and even a calc. to figure your speeds.
    <hr></blockquote> Do not write below this line
    <hr></blockquote>
  5. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    i am going with Jim's numbers.
    curious though where the 1.57 number is from as I have seen it several times now.
    formerly 77chev
    still a jerk though
  6. 55Willy
    Jun 2, 2001
    9,946
    Keizer, Or
    4lo.com list them as
    1st- 6.55
    2nd-3.58
    3rd-1.57
    4th-1.00
    <hr></blockquote>
  7. TXsizeK5
    Aug 26, 2001
    2,518
    College Station, TX
    I got my numbers from a summit catalog.
    87 Custom Deluxe
    305/Sm465/ NP208
  8. ponderingjunkman
    Dec 6, 2001
    14
    Cairo, NY
    Thanks very much!!
  9. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    i am going to have to admit i was wrong.
    my own notes claim 1.58:1 3rd
    so to finalize the issue i opened my spare 465 apart and got the tooth counts.
    i will start mathing it but here is raw data
    input gear is 17 teeth it drives a 40 tooth counter gear
    3rd- 36 tooth counter drives 26 tooth speed
    2nd- 23 tooth counter drives 35 tooth speed
    1st- 14 tooth counter drives 39 tooth speed
    i did it assembled with top cover off and through pto cover
    formerly 77chev
    still a jerk though
  10. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    maybe not after all
    1st = 6.554
    2nd = 3.5805
    3rd = 1.699
    4th = 1
    formerly 77chev
    still a jerk though<P ID="edit"><FONT class="small">Edited by m j on 01/23/02 07:42 PM.</FONT></P>
