sm465 4wd to 2wd
Discussion in 'The Garage' started by bear76, Mar 5, 2007.
  1. bear76
    bear76 1/2 ton status
    Oct 16, 2005
    1,065
    here
    I have a 4wd 465 and want to use it in a 2wd c10. What do I do?
  2. Chevy305
    Chevy305 6 Lug 14bsf Status Premium Member GMOTM Winner
    Jan 23, 2006
    11,232
    490
    New Hampshire
    you'd have to change out the output shafts so that you can run a driveshaft off of it...
  3. Russell
    Russell LB7 Tahoe Status Premium Member GMOTM Winner
    Jun 23, 2000
    7,925
    337
    Fort McMurray, Alberta
    Change out the rear half of the mainshaft. Pretty easy to do if you've got a bearing puller, snap ring pliers and either a press, or a big hammer with a couple blocks of wood or brass drigs.
  4. dyeager535
    26,980
    Go find a 2wd model, should be $50, not many people want 2wd 465's.
