SM465 and NP203 Case
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 79ChevySB, Aug 7, 2001.
  1. 79ChevySB
    79ChevySB 1/2 ton status
    Jul 8, 2001
    178
    Denver CO
    Just came from the Pull and Save in Denver and they have a SM465 tranny with a NP203 case still bolted into a 74 Chevy truck. All thats needed is four crossmember bolts unbolted and its yours. The motor and bellhousing are gone, but everyerything else is still there. Pedals, dash, and steering column.
    Thought I would let anyone interested know. Good luck.
  2. Kyle89K5
    Kyle89K5 1/2 ton status
    2,273
    OKLAHOMA
    Good eye.
    I know there were a lot of folks looking for this earlier, you might stick it over at parts for sale/wanted too.
    Either way BTT
    Kyle
    89K5
  3. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Did an SM 465/NP 203 combo ever come stock? I thought they were always 205s or 208s.
    Tim
  4. Kyle89K5
    2,273
    OKLAHOMA
    Pretty much only in 74 and only on 3/4 ton trucks
    Kyle
    89K5
  5. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    Also found in some Blazer/Jimmy's.... According to my parts book, any 73-75 f/s truck could be had this way. I got mine from a 77 K10 with 250 inline 6 - I suspect it wasn't original.
  6. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    Someone near there needs to jump on this, these are good parts to have! PLEASE save them from the crusher!!!!! I hate seeing stuff like that get smashed or lost or broken because some wrecking yard guy doesn't care.
    Making the world better, one truck at a time.
    SW-ORD
  7. Batmanjr
    Batmanjr 1/2 ton status
    Mar 23, 2001
    1,537
    Copperas Cove, Texas
    HEY!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    That Combo is worth a fortune. Do you know how hard it is to find the adapter that goes in between a 465 and a 203??????????? If you get this setup, I've designed a way to make an almost bulletproof drivetrain with a 24 to 1 gear ratio out of the motor. This means that if you have 300 ft/lbs of torque at the flywheel, then you've got 7200 ft/lbs of torque through the driveshafts! This is very important. Can you think of a drivetrain with splines of no less then 30 all the way through With gears instead of belts!
    <blockquote><font class="small">In reply to:</font><hr>
    <font color=red>My Wife:</font color=red>"Only two minor cosmetic problems: The inside and the outside!"
    <hr></blockquote>
    1972 K5 502CB,465,203/205Doubler,14FF/D60
