sm465 bellhousing 15" crack
Discussion in 'The Garage' started by stus84, Mar 21, 2005.
  1. stus84
    stus84 1/2 ton status
    Mar 21, 2005
    109
    MN
    Mornin guys - I picked up a 84 Blazer a couple weeks ago, doing some hard wheeling up here in MN and crakced the bellhousing. I did a search and didnt see any tips for removal just wondering if you guys had any. Is it best to romove the case & the tranny at the same time or just any general tips would be appreciated. Thanks! I have pics but am not sure how to post them yet.. I just got all signed up this mornin.
  2. dyeager535
    26,979
    I had written up a big long thing, but after my experience yesterday, I think INSTALLING them seperately in the end is easier. Pulling together is probably easiest, because you can use the crossmember for a floorjack.
    The 465 is hard to line the clutch up anyways, since the top of the case hits the floorpan, at least in my truck. (not much clearance as installed) If the engine is angled WAY down (as much as possible) this will be easier. if the t-case is hanging off the end, and the engine doesn't angle down enough, I suspect both the tranny and the t-case would hit the floor pan as you try and reinstall.
  3. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    I had a heck of a time putting my 465 in without a transfer case on it or without a cab on it. I kept trying to do it with the bellhousing already on and then putting the trans into the bellhousing and clutch. Eventually I gave up and had success with having the bellhousing bolted to the trans and then sliding it on to the motor.
  4. ilikeitloud
    ilikeitloud 1/2 ton status
    Oct 30, 2003
    134
    edina, minnesota 55424
    personally for me i like doing the tranny and then the t-case. i think thats the easiest way..
    off-topic i see that you live in MN. where in MN do you live.
  5. camiswelding
    camiswelding 1/2 ton status
    May 25, 2003
    2,545
    Redding, CA
    I have an excellent aluminum sm465 bellhousing.... 20.00 and the ride
    if that will help at all
    cam
  6. stus84
    Mar 21, 2005
    109
    MN
    thanks
    looks like I will try to pull it all together then install bellhousing, tranny & case seperate. Thanks again.... Stue (Ham Lake, MN)
  7. stus84
    Mar 21, 2005
    109
    MN
    thanks cam
    I have one on the way already though.
