SM465 bellhousing Q?
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by mitchelm, Jan 19, 2006.
  1. mitchelm
    mitchelm Registered Member
    Jul 11, 2005
    16
    NJ
    Okay, so doing the sm465 swap for what seems to be a saginaw 3 speed on my 72 blazer. I have the sm465, transfer case adapter and a new 205 to go with it. My question is, before i teake everything apart, will the bellhousing from my heavy duty 3 speed work with the sm465. Or will i need a different one, along with probably all new clutch components. Thanks. Dont want to tear into my truck again, and then not beable to swap everything and have my truck sitting again.
  2. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    I don't know for sure...but I would guess you need a 465 bell. I would think the bolt pattern is different on the 3speed...but again I don't know for sure:confused:
  3. Yukon Jack
    Yukon Jack 1/2 ton status
    Jul 25, 2002
    1,984
    Rose Hill, KS
    When I was preparing to swap my three speed for the SM465 I was told the hole in the bellhousing where the transmission attaches is different sizes. I never confirmed as I used a hydraulic clutch bellhousing when I swapped in the SM465. I had other people tell me they were the same. Sorry I can't give you a definite answer.
  4. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    i just took this set up out of my 68 burb to put in a 465-208. the bell housing will bolt up if you through bolt the bottom two holes. the bad thing is you have to run the funky 3 bolt starter instead , it bolts to the bellhousing and not the motor.
  5. mitchelm
    Jul 11, 2005
    16
    NJ
    i see. damn 3 spds. haha. I wound up buying the correct sm465 bellhousing off of ebay. I let you guys know what happens. Thanks again for all the help
    Mike
