sm465 clutch and power and mustard
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by mudddog91, Aug 3, 2001.
  1. mudddog91
    mudddog91 1/2 ton status
    Dec 28, 2000
    471
    north carolina
    Hey anyone running a centerforce clutch with one of these off road?I need to change my clutch cause every time I climb over that big boulder pile my clutch decides to take up smoking!Which clutch would you guys reccomend??????
  2. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    I've run Napa's heavy duty clutches on SM465's and NP235's with no slipping at all. The only trouble I ever had was one that had a defective disc that literally exploded the first time I engaged it.
    Generic Signature
    <a target="_blank" href=http://pugsley.alloffroad.com>pugsley.alloffroad.com</a>
  3. RedDwarf
    RedDwarf 1/2 ton status
    May 9, 2001
    816
    North Central Florida
    When you replace, make sure your flywheel is free of oil. wipe it off with brake cleaner.
    Then make sure the linkage is adjusted right.
    What's your motor/gearing/tire size?
    Lift It, Lock It, LIVE IT!!!
  4. ScoobyDann
    ScoobyDann 1/2 ton status
    Mar 9, 2001
    305
    El Paso, TX (Far West Texas near Las Cruses
    i got the centerforce II. love it takes a real beating and it keeps going
    sun desert offroad http://community.webshots.com/user/scoobydann
  5. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    My friend has one with a truck with a 350 with 3.73 gears on 44s and has no problems. He has the dual friction. Oh yeah, he never uses 4 low. Never.
    Tim
  6. mudddog91
    Dec 28, 2000
    471
    north carolina
    Im running a 383 stroker,4.10:1 gears and hopefully a set of 38's.I smoked the clutch while running 33's!!!!!!!!!!!!
  7. 4x4blazer
    4x4blazer 1/2 ton status
    Jun 14, 2000
    278
    Louisiana
    As for the mustard, I recomend Grey Poupon.......
    lol, sorry, couldnt resist.
  8. morphed86k10
    morphed86k10 1/2 ton status
    Jun 25, 2001
    463
    Reno Nevada
    are you saying that with 3.73 gears and 44 inch tires, he never uses 4low when wheeling? That shocks me!
  9. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    I am running the CenterForce II clutch kit. The presure plate is sweet!! it has multipul fingers and balance weights. I have had it in my rig for 5+ yrs now and still on the same adjustment, never been an issue while off roading. It has allways hooked up and I have yet to smell any buringclutchsmell. WAY better than that damn 3 finger pressure plate I took out!! Oh ya eaither get a new flywheel or have your resurfaced...
    CenterForce ROCKS!!!
    <a target="_blank" href=http://www.geocities.com/baja/5099>www.geocities.com/baja/5099</a>
  10. mudddog91
    Dec 28, 2000
    471
    north carolina
    I think im sold on the centerforce clutch idea....but I have yet another problem....has anyone ever had to replace bushings in the linkage that is btween the frame and transmission?Ive got alot of flex in there whenevr I hit a bump or get tweaked off road it moves the clutch pedal and all....Ive got brand new motor and tranny mounts so I know thats not the problem.Help please?&gt;
  11. dyeager535
    26,982
    191
    Hmm. Everyone on the car lists has had bad luck with centerforce. Not so here it appears. I used a Sachs (probably prounounced "sucks" lol) diaphram style (multiple fingers, not 3) and it kicks ass. Nice and smooth, and I haven't made it slip except when I was going 10mph in 4th (or is it 3rd guys lol) and had the gas to the floor.
    Dorian
    My tech/links page: <a target="_blank" href=http://www.dorianyeager.com/index2.html>http://www.dorianyeager.com/index2.html</a>
    No anti-theft measures on your truck? No pity when its stolen
