sm465 clutch needs replace
Discussion in 'The Garage' started by chevy wrangler, Jan 31, 2007.
  1. chevy wrangler
    chevy wrangler 1/2 ton status
    Jun 15, 2006
    3,035
    el paso, texas
    okay so late ly my clutch has been slipping alot, dunno why . it smells like clutch all the time!!! so i need a new one, i have tried the search option but cant seem to find any answers. i found a clutch on ebay and i cross refrened it to this http://www.northernautoparts.com/ProductModelDetail.cfm?ProductModelId=15299
    will this work on my truck?? its a 1979 chevy with a 350 and a 465:confused:,,
    does anybody know where i can find a clutch for cheap??? help a poorboy out guys!!
    thanks
  2. chevy wrangler
    Jun 15, 2006
    3,035
    el paso, texas
    oh and btw i found that the luk clutches are the best, what size would i need 11" or 12"??thanks again guys
  3. chevy wrangler
    Jun 15, 2006
    3,035
    el paso, texas
  4. MattK
    MattK 1/2 ton status
    Jan 12, 2005
    1,713
    Dallas, TX
    looks good to me. dont forget to consider the flywheel. it will need to be resurfaced, if not replaced.
  5. chevy wrangler
    Jun 15, 2006
    3,035
    el paso, texas
    yeah i gotta find a place that will do that
    but is $140 good for a luk??
  6. MattK
    Jan 12, 2005
    1,713
    Dallas, TX
    i suppose. i paid $250ish for my 12" luk pro gold
  7. chevy wrangler
    Jun 15, 2006
    3,035
    el paso, texas
    how do i know what size i need??
    does it matter??
  8. BlaKK54Speed
    BlaKK54Speed 1/2 ton status
    Dec 14, 2006
    242
    Omaha, NE
    you need the 11" clutch. i just did mine a week or two ago. went in like cake. 11" 10 spline 1 1/8 shaft. i paid 100 for mine at autozone, i just got the cheap one (duralast) it has a lifetime warranty. so far it has done outstanding. i dont foresee any future problems
  9. chevy wrangler
    Jun 15, 2006
    3,035
    el paso, texas
    thanks i think ima go with the luk, so umm whats the best way to install it?? i dont wanna take out the motor, like i did on the other truck?????
  10. Jishory
    Jishory 1/2 ton status
    Jan 8, 2002
    1,367
    Palmdale, CA
    camsk5 hooked it up with a centerforce dual friction when i bought my 465/205 combo off him, it hooks up really good and doesnt seem to be wearing that fast at all, check into those
  11. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,995
    134
    I believe the 11" and 12" clutch fit the same flywheel. I went for the 12", and would suggest the same for anyone's rig that sees anything further than street duty.
  12. 1977k5
    May 26, 2003
    9,995
    134
    I have a Centerforce II and would not ever get anything else. If the extra $100 cost is worth it anywhere in your rig, its in the clutch.
    I replaced the clutch (with the help of my dad) at ~140K with a Napa clutch. It was noticibly better than the original clutch that was in the truck.
    When I rebuilt/stroked the motor I decided on a Centerforce and would never consider anything else in the future for any application that is demanding from the clutch. Everything about it is better: pedal force, ease of engagement, grip (if you need it), etc.
    My brother has a Centerforce dual friction in his LT1 Camaro and I feel the same way about that.
  13. chevy wrangler
    Jun 15, 2006
    3,035
    el paso, texas
    okay so now im confused!! what is "the best bang for my buck"???
  14. 5trucks
    5trucks 1/2 ton status
    Aug 12, 2005
    169
    Yuma Az.
    I too would like to know the best way to change these. Mine needs it something awefull. Thanks!
  15. colbystephens
    colbystephens 1 ton status GMOTM Winner
    Feb 24, 2005
    10,924
    20
    Oregon
    best way - drop the tranny. less to unhook.
  16. madmike
    madmike 1/2 ton status
    Jan 23, 2002
    496
    ohio
    You should be able to run a 12" clutch. If not, 11" will be OK. If you don't have a high horsepower engine, and your tires are well matched to your gear ratios, a stock type LUK clutch will be fine, and $150 is a good ball park figure. There's really no good reason to run a high dollar clutch, if you have a mostly stock set-up.
    I drive a 1983 K10, 305, SM465, 3:08 gears, stock size tires, with over 154K miles on it and original clutch. It still doesn't need a new clutch!
    On the other hand, my trail truck is a 1974 K10, 454, SM465/NP205/NP203, 4:10's, 38's, and locked front and rear. I use a stock type Zoom clutch from Scummit Racing in it. I've smoked it a little a time or two, but so far, it still works fine. When it quits, I'll probably switch to a Centerforce then.
    Good luck!
  17. BlaKK54Speed
    Dec 14, 2006
    242
    Omaha, NE
    i will admit the centerforce is probably the best for your money, if i had the cash i would have bought it.
    the best way is to get a good tranny jack and just lower the trans and t-case all at once. i spent 2 days on mine and only took that long because of the shops hours i was using. (on base)
  18. chevy wrangler
    Jun 15, 2006
    3,035
    el paso, texas
    well ima check the gm crate engine we took off of the 3/4 ton truck . we took it off because it smoked and found out some of the rockers were off , so this weekend ima check the pistons and if all is well i'll just swap engines with a new clutch in it
