sm465 clutch problem!!
Discussion in 'The Garage' started by chevy wrangler, Oct 23, 2006.
  1. chevy wrangler
    chevy wrangler 1/2 ton status
    Jun 15, 2006
    3,035
    el paso, texas
    well how do u know when your clutch plate is gone?? i dont know much on trannys, so like what are some things to look for on a sm465?? what are the signs of worn clutch plate??:confused::confused::confused::confused::confused::confused:
  2. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    it'd help us if you could describe what it is doing or not doing...
    Clutch chatter and slipping are fairly obvious signs you have a problem.
    Rene
  3. chevy wrangler
    Jun 15, 2006
    3,035
    el paso, texas
    it bounces hard on take off like at a stop sign and lights, it shakes the truck like crazy!!!!
  4. bigred81
    bigred81 1/2 ton status
    Dec 5, 2003
    323
    Falls City,TX
    All you are feeling is the clutch chattering which can be cause by oil on the clutch disc, warped pressure plate, clutch not fully releasing, and many others. If not to bad just live with it. If to bad full the tranny to check the flywheel or replace the clutch. Some times just adjusting the linkage can solve the problem.
    bigred81
  5. chevy wrangler
    Jun 15, 2006
    3,035
    el paso, texas
    well yeah but what i do once and a while is pressure wash the cluch and i let it out slowly and it hasent done it lately
  6. colbystephens
    colbystephens 1 ton status GMOTM Winner
    Feb 24, 2005
    10,924
    20
    Oregon
    sounds like you have a bad u-joint. my truck shutters as i begin to move when i've got a bad ujoint - i have the sm465.
  7. chevy wrangler
    Jun 15, 2006
    3,035
    el paso, texas
    from where??
  8. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
    get under your rig and pull/push on the driveshaft near the ujoints and see if there's excessive play. i would lean VERY heavily in the direction of a bad ujoint... i've been there: [​IMG] your description matches mine just before i checked this. :D this is pretty extreme tho and was due to some other issues you aren't likely to have. this is the joint which attatches to my 205. don't know if you've got a 205 or a 208 - so check both if you've got a 205, or the one at the pinion yoke w/ a 208.
  9. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
    don't know if my last post made sense. looks like you've got an sm465/205 set up. there are ujoints which connect the driveshaft to both the tcase and pinion yoke. check those. :)
  10. chevy wrangler
    Jun 15, 2006
    3,035
    el paso, texas
    205 and i know that the passengers side ujoint on my 44 is gone but i drive around in 2hi and the hubs unlocked.....
  11. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
    different u-joint. i'm talking about the one on the driveshaft that goes from the transfer case to the rear axle. there's one on either end of the driveshaft. check those.
  12. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
    it's a 15 dollar part. sorry - computer's not letting me edit, so i have to keep doing new replies.
  13. chevy wrangler
    Jun 15, 2006
    3,035
    el paso, texas
    well my rear d-shaft is okay
  14. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
    i'm sure your driveshaft is fine - but i really doubt your u-joints are.
  15. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    Clutch chatter is usually caused by oil on the clutch disc...do you have any leaks at the rear of the motor?
    Rene
  16. chevy wrangler
    Jun 15, 2006
    3,035
    el paso, texas
    umm yeah my rear main leaks
  17. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    Yeah, that'd be the problem then. I just did this on my 6.2 and have had to do it to my old 350 too. Both clutches chattered, although the 6.2 clutch would smooth out the more you used it.
    To really fix the problem you'll obviously need to repair the rear main seal, then have the flywheel resurfaced, new clutch disc and pressure plate.
    Rene
  18. chevy wrangler
    Jun 15, 2006
    3,035
    el paso, texas
    ?? how do i fix the rear main??
  19. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    Drop tranny and T-case, remove clutch and pressure plate from flywheel, remove flywheel, remove oil pan, unbolt the rear main bearing cap. The rear main seal halves seat in the rear of the block and the rear main cap. I use a small wooden dowel to push out the old seal half from the block, the half in the rear main cap you can just pull out.
    Push the new seal half into the groove in the block, install the other new seal half in the cap and bolt it back up.
    A Chilton's will have some pic's and a better description.
    Basically a buttload of work for a $25 part...
    Rene
  20. chevy wrangler
    Jun 15, 2006
    3,035
    el paso, texas
    ?? dosent a 350 have a one piece seal??
