Sm465 doubler Question
Discussion in 'OffRoad Design' started by cegusman, Aug 23, 2005.
  1. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    I have a sm465 to np203 adaptor from a 10 spine setup, and a 32 spline np203. If I find a sm465 with the 32 spline output that was mated to a np208, will I be able to use it to mate the the 32 output shaft to the np203 with the factory 465-203 adaptor. Or do I have to buy your 32 spline trans shaft from you?
  2. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    Unfortunately the factory 32 spl. output shaft is about 4" too long, so you have to use our 32 spl. shaft with the short adapter. We have a batch of the shafts due to be finished in the next week or so.
    The only way to use the factory 32 spl. output shaft is to re-drill the front of the 203 and bolt it to the 208 adapter.
    It's quite a puzzle to put together sometimes.
  3. cegusman
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    Thanks for the quick reply.
    What is all invalved in swaping the shaft in the sm465?
  4. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,224
    94
    Stevens Pass Highway, WA
    Basically a complete tear down and rebuild. Not hard to do though if you can rebuild a motor.
  5. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    at least you won't have to pull the lower gear cluster, that helps.
  6. eshorvath
    eshorvath 1/2 ton status
    Jun 20, 2002
    373
    Southern Oregon
    where can i get an adapter for a NP208-SM465 mate? Mide cracked today. Ouch!
  7. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    I'd try a 'yard first, they're relatively common. We don't have any to spare since they're a good way to mate a 203 and SM465 and tend to leave quickly, but a wrecking yard may have one available.
  8. OnetonCowboy
    OnetonCowboy Registered Member
    Sep 1, 2005
    29
    TX
    What do you guys get for the shortie 32 spline output? I didn't see it listed on your site.
    TIA
    Elliott
  9. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    It's been varying batch to batch due to batch size and material price but the last bunch was $340. I'm thinking the current batch should be a bit less but probably not much.
  10. OnetonCowboy
    Sep 1, 2005
    29
    TX
    Ok, Thank you very much for getting back to me.
  11. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    Nothing final yet but it looks like the shaft price will be right around $300.
