sm465 fluid?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BowtieBlazer, Sep 14, 2001.
  1. BowtieBlazer
    BowtieBlazer 1/2 ton status
    Jul 15, 2001
    2,462
    Baton Rouge, Louisiana
    What do you guys out there with the 465 run in your tranny?
    I was told to go with the sludge 85-140w
    1985 GMC C-10 Shortbed
    1984 Chevy K-5 Blazer
    1982 Chevy C-10 Longbed
  2. thatK30guy
    Jan 12, 2001
    32,076
    55
    85-140 is fine.
    The more common oil is the 80-90 weight oil, which I use.
    <font color=red>I'm a "black top mudder"!!!</font color=red>
    <a target="_blank" href=http://coloradok5.com/gallery/thatK30guy>http://coloradok5.com/gallery/thatK30guy</a>
  3. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    I put 85W140 in mine in the dually - I like good heavy oil[​IMG]
    Special thanks to those lost from IAFF Locals 94 and 854 - You shall never be forgotten
    <a target="_blank" href=http://pugsley.alloffroad.com>pugsley.alloffroad.com</a>
  4. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    It might help to mention that if your truck sees any cold weather at all 80 W 90 might be a better choice.
    Rene
  5. BowtieBlazer
    Jul 15, 2001
    2,462
    South Louisiana....it gets below freezing about a week out of the year and thats not consecutively
  6. simpleman83
    simpleman83 1/2 ton status
    Oct 18, 2007
    120
    Atlanta, GA
    I just changed my clutch and I'm going to replace the fluids too. Can I use the 85W140 in the NP208 also? Or should I use something else? I'm in GA so, probably don't need the lightweight stuff either...
  7. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    trans fluid in the 208
  8. simpleman83
    Oct 18, 2007
    120
    Atlanta, GA
    Why not just use trans fluid in both then? I assume Dextron/Mercon III or whatever....
  9. Chevy305
    Chevy305 6 Lug 14bsf Status Premium Member GMOTM Winner
    Jan 23, 2006
    11,232
    490
    New Hampshire
    the sm465 is purly metal on metal gears and was designed in the 60s so gear oil is what it calls for. The 208 is an 80s design with gas milage considered thats why its designed to be used with the much lighter weight ATF.
