SM465 gasket
Discussion in 'The Garage' started by cegusman, Dec 23, 2002.
  1. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    When replacing the gaskets do i need to use rtv, It does not look like there was any there in the first place, is that the same for the np205?
  2. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    with a gasket you are never suposed to use rtv
  3. cegusman
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    ok thanks
  4. 87sm465np208
    87sm465np208 1/2 ton status
    Aug 28, 2002
    1,114
    illinois
    my drain plug was rusted so bad on my 465 that i couldnt get it off, so i drained it through the PTO cover on the drivers side, uh oh, i ripped the gasket, rather then going through the pain and anguish of getting another gasket, i squeezed some blue RTV on it after i cleaned the gasket off, worked really well./forums/images/graemlins/thumb.gif
    /forums/images/graemlins/usaflag.gif
    /forums/images/graemlins/truck.gif
  5. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    But in many cases, it will leak without RTV. You have to decide how the sealing surface looks, the mounting location, the gasket material, the fluid it's sealing, how often you take it apart, yada yada... basically, It's up to you how you do it, and how easy you want the cleanup to be when you have to put it back together. For the top of the 465, I wouldn't say the need for RTV is there ..........
  6. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Mine leaks. /forums/images/graemlins/smile.gif
